I am trying to export a raster, it keeps stating export failed without any error notes.
I have tried PNG, JPG, JPEG, and PDF
Are you exporting from a File Geodatabase? If so try exporting as a .TIFF
Didn't work for me, "Export Failed" I wish it would at least give me the error reason.
If you click 'View Details' when it tells you Export Failed, it should give you an Error code with a link to a solution
As stated, it isn't giving an error message, there isn't a View Details like normal. Just Export Failed.
Can you try making a copying the layout to a new project and then exporting? There's an export bug in 3.1 that should be fixed in an upcoming patch with some exports. In the meantime, copying the layout to a new project usually fixes the problem.
