function onRowClickHandler(evt) { var ClickedId = grid.getItem(evt.rowIndex).ASSETID; var selectedId=0; //var symbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DASH, new dojo.Color([255, 0, 0]), 3); dojo.forEach(advancedMapObj._layers.SearchResultLayer.graphics, function (graphic) { if ((graphic.attributes) && graphic.attributes.ASSETID === ClickedId) { selectedId = graphic; return; } }); if(selectedId) { var selectedExtent = selectedId.geometry.getExtent(); //selectedId.setSymbol(symbol); //map.graphics.add(selectedId); map.setExtent(selectedExtent); //I wrote this part of code so as to get a point on the polyline i was interested in var length = graphic.geometry.paths[0].length; if (length % 2 != 0) length = length - 1; var pointxy = graphic.geometry.paths[0][(length / 2)]; Infopoint = new esri.geometry.Point(pointxy[0], pointxy[1], new esri.SpatialReference({ wkid: 102100 })); //and after setting the info template map.infoWindow.show(Infopoint,basicMapObj.getInfoWindowAnchor(Infopoint)); } else { alert("Assets not mapped properly"); } }
// Listener event to retrieve the recordID of the record in the datagrid that the user clicked on dojo.connect(dijit.byId("grid"), 'onRowClick', function(e) { var rowdata = grid.getItem(e.rowIndex); var theId = rowdata.OBJECTID; theFeatureLayer.clearSelection(); var query = new esri.tasks.Query(); query.objectIds = [theId]; theFeatureLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW,onRowClickHandler); });
I had a strange behaviour of popup in my app for a similar kind of approach.On click of grid the popup appears for the first time and when i click on next grid it only zooms to that level but without popup.a click again on the same grid, gets the popup back or even the zoom out of map helps. Not sure why this stuff happens!Trying to replicate the same, couldn't find much luckHere's the fiddle.search for Owner name Katzto see such a behaviour first click on row192717701 Sidney F Katz Null 1966 1379 Stuyvessant Rd and then on190745300 Samuel Katz Null 1982 3377 Indian Summer DrNot sure why this happens with only these two pairs but i have this prob with every row in my app.Whats making this happen?
//Select an offender in the data grid function onRowClickHandler(evt) { var clickedOffender = grid.getItem(evt.rowIndex).OBJECTID; var selectedAddress; for (var i = 0, il = map.graphics.graphics.length; i < il; i++) { var currentGraphic = map.graphics.graphics; //assign selection to a graphic if (currentGraphic.attributes.OBJECTID == clickedOffender) { selectedAddress = currentGraphic; break; } } //automatically show popup map.infoWindow.setContent(selectedAddress.getContent()); map.infoWindow.setTitle(selectedAddress.getTitle()); map.infoWindow.show(selectedAddress.geometry, new esri.SpatialReference({ wkid: 102100 })); //set the point extent and spatial reference, to zoom in //requires a value (250 or 500 work well) for adding or subtracting from xmax,xmin,ymax,ymin var factor = 250; extent = new esri.geometry.Extent( selectedAddress.geometry.x - factor, selectedAddress.geometry.y - factor, selectedAddress.geometry.x + factor, selectedAddress.geometry.y + factor, new esri.SpatialReference({ wkid: 102100 })); map.setExtent(extent); } dojo.addOnLoad(init);
Pramod and Derek: I too I'm having similar problems - with On click of a row in the datagrid the popup appears for the first time perfectly placed to the right and centered. (Note: If at this point I zoom in/out and then click another row in the datagrid it will work perfectly again.) However if I don't change the zoom level and I click another row in the datagrid it zooms to that level but popup is only partially in the view. I've attached my code and some screen shots. One of the problems I had earlier was the zoom. I'm using base maps and map layers all projected in Web Mercator (102100) and I'm zooming to a point. If you're doing this you need to set extent by adding to & subtracting from the point geometry. I'd welcome some help - thanks.
//row click counter x = x + 1; //known bug in popup window, my workaround is to alternate the factor variable var factor; if (x % 2 === 0) { factor = 1000 } else { factor = 1500 } //set the point extent and spatial reference, to center & zoom in //factor must be no greater than 1500 so clusters are singles extent = new esri.geometry.Extent( selectedAddress.x - factor, selectedAddress.y - factor, selectedAddress.x + factor, selectedAddress.y + factor, new esri.SpatialReference({ wkid: 102100 })); map.setExtent(extent);
Derek:I do have it working. My work around was to create a counter and determine if it was even or odd. Depending on the result the factor added/subtracted from the extent alternates between two values. It's not very pretty so maybe someone out there can suggest some changes to make it a little more elegant. Thanks for your help.//row click counter x = x + 1; //known bug in popup window, my workaround is to alternate the factor variable var factor; if (x % 2 === 0) { factor = 1000 } else { factor = 1500 } //set the point extent and spatial reference, to center & zoom in //factor must be no greater than 1500 so clusters are singles extent = new esri.geometry.Extent( selectedAddress.x - factor, selectedAddress.y - factor, selectedAddress.x + factor, selectedAddress.y + factor, new esri.SpatialReference({ wkid: 102100 })); map.setExtent(extent);
<!DOCTYPE html> <html xmlns="http://www.w3.org/1999/xhtml"> <head> <title>Dynamic layer template with datagrid test</title> <link href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/dojo/dijit/themes/claro/claro.css" rel="stylesheet" type="text/css" /> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/dojo/dojox/grid/resources/Grid.css"/> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/esri/css/esri.css" /> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/" type="text/javascript"></script> <script>var dojoConfig = { parseOnLoad: true };</script> <script type="text/javascript"> //Ken Burcham - from many examples - 3/20/13 //CTUIR - GIS dojo.require("dojo.parser"); dojo.require("esri.dijit.Popup"); dojo.require("esri.map"); dojo.require("esri.dijit.Scalebar"); dojo.require("esri.layers.FeatureLayer"); dojo.require("dijit.form.Button"); dojo.require("dijit.form.TextBox"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dojox.grid.DataGrid"); dojo.require("dojo.data.ItemFileReadStore"); var map; function init() { //define custom popup options var popupOptions = { markerSymbol: new esri.symbol.SimpleMarkerSymbol("circle", 32, null, new dojo.Color([0, 0, 0, 0.25])), marginLeft: "20", marginTop: "20" }; //create a popup to replace the map's info window var popup = new esri.dijit.Popup(popupOptions, dojo.create("div")); //define a popup template var popupTemplate = new esri.dijit.PopupTemplate({ title: "Study Site: {StudySiteID}", fieldInfos: [ { fieldName: "Description", visible: true, label: "Description" }, { fieldName: "Latitude", visible: true, label: "Latitude" }, { fieldName: "Longitude", visible: true, label: "Longitude" }, { fieldName: "RiverName", visible: true, label: "River" } ], showAttachments: true }); map = new esri.Map("map", { sliderOrientation: "horizontal", center: [-118.45, 45.56], zoom: 10, infoWindow: popup }); //define my basemap var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer"); map.addLayer(basemap); //define our overlay layer of the reservation var boundary = new esri.layers.ArcGISDynamicMapServiceLayer("http://restdata.umatilla.nsn.us/arcgis/rest/services/TribalLands/MapServer"); map.addLayer(boundary); //define the feature layer which will be our water temp study sites // api reference: http://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/featurelayer.html var featureLayer = new esri.layers.FeatureLayer("http://restdata.umatilla.nsn.us/arcgis/rest/services/StudySites/MapServer/0", { mode: esri.layers.FeatureLayer.MODE_SNAPSHOT, //using this mode starts off showing all of the points infoTemplate: popupTemplate, outFields: ["StudySiteID", "Latitude", "Longitude", "Description", "RiverName"] }); //clicking on the map should show the infowindow for that point dojo.connect(featureLayer, "onClick", function (evt) { map.infoWindow.setFeatures([evt.graphic]); }); //populate our datagrid with all of the studysite data dojo.connect(featureLayer, 'onLoad', function (layer) { var query = new esri.tasks.Query(); query.where = "1=1"; layer.queryFeatures(query, function (featureSet) { var items = dojo.map(featureSet.features, function (feature) { return feature.attributes; }); var data = { identifier:"StudySiteID", items: items }; store = new dojo.data.ItemFileReadStore({ data:data }); try { var layout = [[ { 'name': 'Study Site ID', 'field': 'StudySiteID', 'width': '100px' }, { 'name': 'River Name', 'field': 'RiverName', 'width': '140px' }, { 'name': 'Description', 'field': 'Description', 'width': '660px' } ]]; var grid = new dojox.grid.DataGrid({ id: 'grid', store: store, structure: layout, rowSelector: '20px' }); grid.placeAt("data"); //this is the div below that we want to fill grid.startup(); //connect to the onRowClick event - clicking a row should show the studysite in the map grid.onRowClick = function (e) { zoomRow(e.grid.getItem(e.rowIndex).StudySiteID); }; } catch (err) { console.dir(err); } }); }); map.addLayer(featureLayer); //set our infowindow dimensions dojo.connect(map, "onLoad", function (map) { map.infoWindow.resize(270, 180); }); //zoom in the map to this point (called when someone clicks a datagrid row) //param: id = StudySiteID function zoomRow(id) { try { var query = new esri.tasks.Query(); query.objectIds = [id]; featureLayer.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_ADD, function (features) { //zoom to the selected feature and show the infowindow map.infoWindow.setContent(features[0].getContent()); map.infoWindow.setTitle(features[0].getTitle()); map.infoWindow.show(features[0].geometry); //map.infoWindow.resize(270, 180); //not necessary }); } catch (err) { console.dir(err); } } var scalebar = new esri.dijit.Scalebar({ map: map, attachTo: "top-left" }); } dojo.addOnLoad(init); </script> <style> html,body,#mapDiv,.map.container { padding:0; margin:0; height:100%; } </style> </head> <body class="claro"> <div id="map" style="width:100%; height:80%; border:1px solid #000;"></div> <div id="data" style="width:100%; height:20%"></div> </body> </html>
This is the line that does it:map.infoWindow.show(features[0].geometry); So you might have to check the response you get back from the server and make sure "features[0]" has a populated response from the query.ken.
Oh, you mean pan the MAAAaaaaap! Yeah, that just shows the infowindow. I hadn't tried to get the pan the map thing working yet. I think there was a setExtent method that might do that.Arg, I'm a moron. Sorry! 🙂ken.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
