Hi,I think there might be an issue with the Application Builder Download for 3.2 (the .air file). the download keeps failing around 10MB - I have tried downloading with IE, Firefox and Chrome and get the same result. The Source code and compiled packages are fine.Thanks,Chris
... the compiled version does not contain apps folder that includes localized configuration files.
To create a localized application, the better way is to use the Application Builder.
Kathryn,Have a look at the help for managing custom widgets here:http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Managing_custom_widgets/01m30000004m000000/RegardsAnthony
My legend widget from a 3.1 application does not populate in an upgraded 3.2 application. Is anyone else seeing this?
Dominique, The answer is that the widget was updated to the new ArcGIS Server 10.1 standard and no longer functions for 10.x server. Here is a thread that provides a code work around (make sure you read the whole thread page).http://forums.arcgis.com/threads/78715-Deactivate-zoom-button-on-zoom
I have further narrowed down that this behavior happens on my secured services. All unsecure services populate just fine. Has Esri sunset support for secure services with the legend widget on this release? I am using 10.0 sp3. I did not see anything like that explained in the changelog-- so I'm confused.The legend widget was working fine with my secure services in the 3.1 version of the viewer.
Yeah so, the LEGEND widget does not populate with secure services from 10.1 Server either.... IS ANYONE ELSE SEEING THIS?
