I can't find heat map symbology in the new version 3.1; how can I symbolize a layer with heap map?
Heat map symbology draws point features as a dynamic, representative surface of relative density.
You have selected a polygon layer. It's not possible to create a heat map from a polygon layer.
You can choose a different method - such as an attribute (population) to symbolize the boundaries?
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/heat-map.htm#ESRI_SECTION1_AE1701C38B7B46CAA0C1725D7D282A98
Above documentation link has the steps.
If you can't see it:
I have selected my layer, but in the symbology pane, primary symbology down arrow I can't find heat map.
