Hola tenemos el mismo mensaje
Added error for extent -60.595805 -33.904033 -60.527735 -33.856800 at scale 750 in main loop. J = -1 submittedJobs = 2
Origen: System/CachingTools.GPServer
En conjunto con este otro:
Error executing tool.: TilesWorker: Output failure, error string = Error writing tile, level=16, row=474865, col=371478 Failed to execute (Manage Map Cache Tiles Worker).
Tenemos Windows 2012 R2 corriendo ArcGis Server 10.1 SP1, la BD esta en otro servidor con directconect y es Oracle 10G.
Si pueden ayudarnos, mientras seguiremos investigando el tema.
Saludos,
What version of ArcGIS Server are you using?
Where is your data to be cached stored (e.g. SDE (SQL Server, Oracle), file geodatabase, personal geodatabase)?
Gracias por interesarte, tenemos Windows 2012 R2 corriendo ArcGis Server 10.1 SP1, la BD esta en otro servidor con directconect y es Oracle 10G.
Do you know if Oracle is in a Real Application Clusters (RAC) environment with Transparent Application Failover (TAF)? You might need to talk to an IT person such as a Database Administrator (DBA) for the answer to this question.
Old topic, but may be still relevant to those migrating from ArcMap to ArcGIS Pro based environments.
I had used an old tiling schema XML from around ArcMap 10.4 for publishing a service with ArcGIS Pro 3.0.3 & Server 10.9.1, which caused these same very unspecific errors.
Error - Output failure, error string = Error writing tile, level=4, row=48, col=64§TilesWorker: Output failure, error string = Error writing tile, level=4, row=56, col=64§TilesWorker: Output failure, error string = Error writing tile, level=4, row=48, col=72§TilesWorker: Output failure, error string = Error writing tile, level=4, row=56, col=72
I recreated the tiling schema XML using the ArcGIS Pro toolbox tool "Generate Tile Cache Tiling Scheme" and then it worked.
