Is there any way to preserve OBJECTID while exporting feature class to another EGDB using Feature class to feature class ?
I have found that using the copy function in ArcGIS Desktop keeps the OBJECTID values of the source feature class. Feature Class to Feature Class does not reliably, in my experience. I am not sure if these statements are true in ArcGIS Pro. I still wouldn't count on OBJECTID column being preserved when moving a feature class from one source to another and would recommend abandoning any workflows that rely on the OBJECTID values.
Hi @TonyContreras_Frisco_TX , Yes the copy function works in both Desktop and ArcGIS Pro and It can retain the OBJECTID.
Hence I wrote the below python to achieve it.
As OBJECTID is a system created primary key, none of the tools are going to keep it other than by luck. If you want to retain the value, create a new column in the feature class with same data type as OBJECTID, maybe with a name like old_objectid. The use the field calculator to set the old_objectid = OBJECTID. Then export.
Hi @DavidAnderson_1701 ,It can preserve the OBJECTID if we use the copy function like @TonyContreras_Frisco_TX mentioned above.And no other ArcPy function can preserve the object if there's any non sequential numbers in it (Like by luck)
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
