Hello,
Is it possible to attribute a single point event to multiple routes? For example if I want to attribute a traffic signal control box to two roads which are separate events how would I go about doing this?
Thank you
@Jol1234 Depending on the situation, there are multiple ways to handle this situation. Suggest reviewing the following resources, test the option that best applies to your use case.
Thank you @AyanPalit,
I was hoping you could elaborate on if route dominance could apply to point events as well as linear ones? Also your bullet point about "Event attributes can be extended to capture secondary route and measure"
Would that just involve having an extra column in the event table for "secondary route"?
