I set up a Field Map project. Everything is working well except the photos collected during the inspection are not showing up in the AGOL map. Instead the parent asset photos are showing in a join view I have with the most recent inspection pop up. I would like the popup for recent inspections to show the recent inspection pictures. I can see the photos in the mobile version if I click a link but do not seem to be able to find the photos anywhere online (as if they are not getting pushed - although the inspection table in AGOL shows attachments). Does any one have any suggestions on how fix this? Thanks in advance for any advice.
For clarification are you trying to view the photos in AGOL or on a mobile device using Field Maps
are you collecting the photos with survey123 or a field maps app
Thanks for the reply. AGOL and field maps are the answers to your questions. I found out recently from ESRI this feature is not currently implemented directly. The technical support services representative that I worked with pointed me to this article but I haven't had a chance to implement as it wasn't critical to the project.
