Hi Peoples,
Is there a Time Slider Widget for the new Experience Builder in AGOL?
I have an app developed with WebAppBuilder that I want to convert over to Experience Builder.
Is there a Developer sample - could look at development.
Cheers,
Mark
The new Timeline widget in ExB has been released today (AGOL 10.2).
Hi Mark,
Currently, we do not have a time slider widget, but it is on our list. You could check out the time slider in the JS API on how to use that widget and review this sample arcgis-experience-builder-sdk-resources/samples/widgets/editor at master · Esri/arcgis-experience-builder-sdk-resources … on how to use a widget from the JS API in Experience Builder.
TimeSlider widget | ArcGIS API for JavaScript 4.17
TimeSlider | ArcGIS API for JavaScript 4.17
David
Hi David,
Thanks for that. I am starting to come up to speed with the apps, but have not got into the development side of things yet. I am aware that more of the widgets from Web AppBuilder will be incorporated into Experience Builder in incremental updates, and as you mention the time slider is on the list. Did you have a rough time frame in mind?
Let's add in Jianxia Song to help out with your question regarding timeslider roadmap.
Hi Mark, the Time Slider widget currently is not in the release plan for Q1 2021. Could you please check in with us 6 months later? Any improvement for Time Slider you would like to see in Experience Builder?
Hi Jianxia,
The current time slider works well. We have an index that represents an aerial photo index over time, so we can use the slider to filter the index see when the photos were taken.
One bug that is problematic is that if the widget is in a map and another widget is selected, the time slider filter is dropped. One needs to have the time slider filter applied, and still be able to use other widgets in the map - so make sure that functionality works.
If the widget is set to be applied automatically when the app is opened, make sure it also works on mobile devices in this way (could be a bug in the current one).
I am also very interested in seeing this implemented!! I see the capability in Web Apps but not in Dashboards or in Experience Builder. I need some tools available in the Dashboards, like being able to select a point and show related photos in an embedded content window, AND time slider functionality. If anyone has suggestions on a no-code solution that incorporates both, please let me know! For now I'm stuck with choosing either/or functionality.
Thanks for the suggestions Mark. Added them to the user requirements of Time Slider.
Not sure if it's exactly what you're looking for, but we were able to add a Web App to Experience Builder inside an Embed widget. Just drag the Embed widget into an empty page and add the link to your Web App to embed it (which contains the time slider widget). It worked for us!
Hello, I would like to see the time slider widget have a unique time interval as an option where given a time aware layer the interval will be set to each unique time value. This is crucial for showing data such as storm events.
@ThomasDarley1 @SolanaFoo2 and all, the Time Slider widget is planned for Q2 2022. We will share the 2022 roadmap after the December update. Thanks.
The first link is no longer working. I need another example of how to use a widget from the JS API in EB. Thanks.
@MichaelWen_Timmons , see the following example of using JSPAI editor widget in ExB:
https://developers.arcgis.com/experience-builder/sample-code/widgets/editor/
I used the approached used in js-api-widget to use the Sketch widget and it was successful. However when I tried to use the same approach with the TimeSlider widget nothing shows. This is the render function I used in widget.tsx:
I noticed that the TimeSlider widget appears inside the map. Does it need to be rendered in a different way?
New Timeline Widget looks nice. I was hoping I could use it with my historic imagery tiled services, but it doesn't look like it works with hosted tiled layers. Boo Hoo
Thank you!!!
Is it possible to use the timeline widget with a WFS? if so, how?
@TonghuiMing When I go to select the data source, I see the pane open up but the page completely freezes and I cannot interact with it anymore. Any ideas? I've got ArcGIS Server services registered in AGOL, feature classes and layers in Web Map are time enabled.
@SolanaFoo2 Based on your screenshots, it seems like the entire app or browser got jammed. It may not relate directly to the Timeline widget but rather more of a performance issue. Is it possible to share the app with me via DM to take a look at?
@ASK1 @MikeSchonlau As you notice, Image layer/service is not supported yet as data source. Your requests have been added to an issue in the backlog.
@SolanaFoo2 - The timeline widget frozen problem should be fixed in the latest AGOL 10.3 release. Thanks for the feedback.
@TonghuiMing Thank you for the follow up! Sorry I didn't contact you, I didn't see a place for DMs and we ended up using a work-around (choosing individual layers). This is great though, thanks!
Yes, choosing layers did work before. Glad to hear that.
Does this apply to layers such as the Sentinel-2 Land Cover/Land Change timeseries, Sentinel-2 views etc? We are hoping to add these using the Timeline Widget but when that dataset is added it is not compatible with the widget.
Hello Eryone!
Is there an update about the image layer/service as a datasource in the timeline widget?
Thanks!
