Hi!
I'm a beginner with Object detection and am trying to go through the process of installing Deep learning libraries. I have been following the workflow in this link
Performing Feature Extraction & Classification Using Deep Learning with ArcGIS Pro (esri.com)
aswell as this
Deep Learning with ArcGIS Pro Tips & Tricks: Part 1 (esri.com)
I have hit a wall when trying to clone the default python environment, i get an error and the cloning step doesn't finalize.
Is cloning the environment a must do? Or can i just skip that part?
Arcgis Pro 2.9.1
Windows 11 education
How are you trying to clone (conda command or ArcGIS Pro Python Package Manager GUI)? What is the error message? Are you in a corporate environment with restrictive IT security?
In the python package manager, It starts to install packages into the clone but it seems to gets stuck on 'torch_geometric-1.7.2'
Error message is
ERROR conda.core.link:_execute(700): An error occurred while installing package 'defaults::scikit-learn-0.24.2-py37hf11a4ad_1'.
LinkError: post-link script failed for package defaults::scikit-learn-0.24.2-py37hf11a4ad_1location of failed script: C:\Users\Ryan\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone-1\Scripts\.scikit-learn-post-link.bat==> script messages <==<None>==> script output <==stdout:stderr: 'conda' is not recognized as an internal or external command,
I'm on a university network so there could be some security issue i guess, either way i'd like to overcome that.
Make sure you see the frameworks here
Esri/deep-learning-frameworks: Installation support for Deep Learning Frameworks for the ArcGIS System (github.com)
Looks like the .scikit-learn-post-link.bat can't find the conda command, try adding the directory that conda is installed to to your PATH environment variable.
Close Pro. Click your Start Menu and start typing environ, select "Edit environment variables for your account" add a new entry to the PATH variable "C:\Program Files\ArcGIS\Pro\bin\Python\Scripts". Then reopen Pro, go to the Python Package Manager and try the clone again.
@Luke_Pinner Thanks so much, had the same problem and this did the trick for me. Had tried reinstalling Pro but that didn't solve it. Not on any sort of work or school network as Ryan suggested, so not sure what causes this.
Thank you Luke. This worked for me as well!
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
