Hi, I was wondering If there is an equivalent to the CheckValue function from ArcGis 10 in the ArcGis Pro 3 API? If not how would I idealy parse out the type of field and check If a string variable would be able to be inserted into a field?
FieldType Property (Field)—ArcGIS Pro in the Pro SDK section of the help. There are separate help topics for non-python help
What I was looking for is this CheckValue function
https://help.arcgis.com/en/sdk/10.0/java_ao_adf/api/arcobjects/com/esri/arcgis/geodatabase/IField.html#checkValue(java.lang.Object)
but for C# .NET SDK
In arcpy's field class
Field—ArcGIS Pro | Documentation
you can check for a field's type
but I suspect you don't want the python api, so if it is for pro's sdk, let me know and I can move your post to the correct part of the Community
