I want to change the color of the coordinate-conversion button only. have tried
.esri-widget--button { background-color:blue; }
but this changes all widgets
Ah. So you want this then:
<SPAN class="selector token">.esri-coordinate-conversion .esri-widget--button</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">background-color</SPAN><SPAN class="punctuation token">:</SPAN> blue<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Richard,
Use this rule then:
<SPAN class="selector token">.esri-coordinate-conversion__select-row</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="property token">background-color</SPAN><SPAN class="punctuation token">:</SPAN>blue<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Thanks for the reply, Robert. However, this changes the select. I want to change the select button as seen below
Hmm... That is exactly what it does for me.
That's the result i got too. However, I actually want to change the button circled below to blue
