Somewhere in conversation, I came across a json url which gives me the number of views on the particular item be it a webmap, app, kml.
Have lost it .Can someone point me out correctly?
Is it something that only an admin can do?
Each item in portal has a property "numViews":
Item—ArcGIS REST API: Users, groups, and content | ArcGIS for Developers
See an example using Python to get the items sorted by the number of views (at the bottom of the page):
Example: Update the URL of a service in a web map—Portal for ArcGIS (10.6) | ArcGIS Enterprise
I guess you will need to have access to the items to be able to retrieve the properties.
Using the ArcGIS API for Python you can do the following:
<SPAN class="keyword token">import</SPAN> arcgis <SPAN class="keyword token">from</SPAN> arcgis<SPAN class="punctuation token">.</SPAN>gis <SPAN class="keyword token">import</SPAN> GIS <SPAN class="comment token"># Org URL</SPAN> url <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fnation.maps.arcgis.com" target="_blank">https://nation.maps.arcgis.com</A><SPAN>"</SPAN></SPAN> <SPAN class="comment token"># Make a connection to the portal</SPAN> gis <SPAN class="operator token">=</SPAN> GIS<SPAN class="punctuation token">(</SPAN>url<SPAN class="operator token">=</SPAN>url<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># Item ID</SPAN> <SPAN class="comment token"># Using a public story map for this example</SPAN> <SPAN class="comment token"><SPAN># </SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fnation.maps.arcgis.com%2Fapps%2FCascade%2Findex.html%3Fappid%3De4ae5b57cf9045288909a93cc31cde7c" target="_blank">https://nation.maps.arcgis.com/apps/Cascade/index.html?appid=e4ae5b57cf9045288909a93cc31cde7c</A></SPAN> item <SPAN class="operator token">=</SPAN> <SPAN class="string token">"e4ae5b57cf9045288909a93cc31cde7c"</SPAN> i <SPAN class="operator token">=</SPAN> gis<SPAN class="punctuation token">.</SPAN>content<SPAN class="punctuation token">.</SPAN>get<SPAN class="punctuation token">(</SPAN>item<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'numViews'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
That's near to what I wanted. We have few items not worth running a script.
Can you give me the Url that returns me the number of items in html , json formats? You know something like <portal>.arcgis.com\sharing\rest\....\....\ where I can view the output
why do certain people come and just post in answers not even fully understanding the question? Everyone here isn't looking for APIs though it's a good medium
Anything you're looking at in the Portal home app is driven from an API...
Anyway, you can use the home app to find the number of views:
https://<portal>.<domain>.com/portal/home/item.html?id=<itemID>
Or users content within Sharing API that the home app is getting its information from:
https://<portal>.<domain>.com/portal/sharing/rest/content/users/<user>/items/<itemID>
Or by searching in the home app:
Or by searching in the Sharing API, which is what searching in the Sharing API is giving you:
Hi all,
is it possible to retrieve the numviews property filtered by user? I mean, is there any log where I could find the items viewed by a user?
Thanks in advance.
I found a bug/error in ESRI REST API, please fix the bug in code or update doc either way:
https://developers.arcgis.com/rest/users-groups-and-items/item.htm
the api reads:
https://<content-url>/items/<itemId>
also give example at bottom
https://www.arcgis.com/sharing/rest/content/items/10ba62fe50864339a8a3e0f18ca85506
You actually will NOT get any info by use above link format. Only a blank page
You must add
?f=json
by define format to get something
This is a working example:
https://www.arcgis.com/sharing/rest/content/items/a22e7905d67f4330bbec630eebd38419?f=json
esri staff, please fix the rest api code, by define 'f=json' format by default.
or update the rest api doc above, by put a NOTE: * remind user must append ?f=json at the url end
Adding f?=psjon will return an easier to read version. But if run within a script, I guess that doesn't matter as much.
Dear all,
Is there any workflow to reset the numviews property without connecting to the portal postgres database?
I cannot find the way to update the property in sharing/rest.
Best
Borja
Hello @BorjaParés_Fuente ,
I came across your comment and this is exactly one of the things I am currently trying to achieve! This was three years ago, but maybe you remember how you solved this? Thanks for any tip you might have.
Xander,
Is it possible to reset the numViews value back to zero?
Note: Exercise extreme caution when connecting to Portal's PostgreSQL database.
A colleague and I just tested and confirmed we can modify the numViews value via Portal's PostgresSQL database. Our use case was publishing new Mobile Map Packages with new names, but we wanted to preserve the legacy file Number of Downloads (which is numViews when accessed via API).
gwdb -> Schemas -> public -> Tables -> gw_items
I'll note this again below, for good measure. 😊
Yes! I posted a solution on another reply in this thread.
