what is your expression and where are you putting it
The Arcade expression sums up the records from related table and it's used in pop-up to a Web map.
When I try to open the map into Field Maps for updating the map the pop-up refuses to display normally. In fact the pop-up doen't come up at all (not only the Arcvade expression but any field in pop-up.
I would suggest configuring the pop up in Pro and publishing it. the new service should show it the desired way.
There are several posts that relationship by name does not work right. See here https://community.esri.com/t5/arcgis-field-maps-questions/add-inspection-related-record-bring-value-from/m-p/1179149#M3712
Workaround is to use Feature set by name and do the filter with a query.
Hope that helps
