The text for several map tour points disappears after publishing. Here's what happened:
Troubleshooting attempt
@JGVadnais -- I apologize that you are having an issue building your map tour. I'm not able to reproduce this issue with the information you've provided, so I'm not sure what might be going on. It could be an issue with your story or a network issue.
Please contact Esri Technical Support and they will be able to help you further troubleshoot this specific issue.
My computer has been reproducing this issue. Please help!
@AlejandraLivingstonPearson -- I'm sorry you are experiencing an issue. Did you by change paste in any text from another source? There is a known issue that some text may not be saved correctly when it's pasted from Google Docs. You can try using the "Paste and match formatting" option. See this thread for more information and workarounds to try.
Re: Pasted Bulleted Text from Google Docs Disappea... - Esri Community
If that's not the issue, please contact Esri Tech Support and they can help you further.
