Hey,
so the issue is as follows. I've got a custom dimensions layout that I want to further process in external 3D modelling software. The problem is that the exported file, whether it's SVG or PDF, doesn't contain annotations (labels converted to annotations) and text elements inserted in the layout view when using Export Layout.
I tried all the setting possible with no success. Saving the project and restarting software/machine does not help. The missing elements are however exported to PDF when using Print Layout option instead but I need vectors to further process them.
Do you have any ideas what might be causing the issue? Thanks in advance!
