Hello!
I have in my Experience Builder the edit tool. The hosted feature layer does allow for attachments to be attached but it is greyed out. When my user clicks the plus sign to add attachment nothing happens. Did I miss a setting? Thanks!
It should work as long as the data supports attachments. Could you provide any sample app or data?
Hello TianWen,
Is the add attachment option still available in the Edit widget of EB?
I have published a hosted feature layer (from survey123 as well as arcgis pro) with attachments enabled. I can see the Add option on the Classic Web Map, but not on the Web Scene or the Edit widget of EB.
Thank you
Yes, it is still available. Would you provide a video or sample data so I can target the problem? Thank you!
Hello @TianWen
Thank you, I have DMed you a gdb
Thanks!
I am having this problem in Experience Builder. There is no ability to add attachments using the Edit widget.
