I was expecting ArcGIS Pro to behave like ArcGIS Online Web Maps. When I bring in any Map Service, I can't figure out a way to change the definition query on layers. Is this not supported functionality?
Example Map Service that can be filtered in a Web Map but not in Pro 2.8.3
https://livefeeds2.arcgis.com/arcgis/rest/services/GEOGLOWS/GlobalWaterModel_Medium/MapServer
You could add the respective layer directly to ArcGIS Pro.
e.g.
https://livefeeds2.arcgis.com/arcgis/rest/services/GEOGLOWS/GlobalWaterModel_Medium/MapServer/0
Definition Query should work with these layers.
Thank you! Yes, I can confirm this works but adding a single layer at a time is not an efficient workflow. I'm curious if this discrepancy in behavior between the Web Map and ArcGIS Pro when working with Map Services is expected behavior or a bug.
Was there ever any resolution on this for you @Matt-Huser? We've run into the same issue (it's not efficient to bring every one of the layers in the map service into Pro separately).
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
