please use this as a example
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=intro-mapview
and im notice that its different, `+` icon and `-` icon highlighting are different, how do i align them like how do i align the - icon?
Not sure if there's a better way, but you can add this to your CSS
.esri-zoom .esri-widget--button:first-child { margin-bottom: 2px; }
@altair
You could use CSS. Here I changed it to red.
Greetings Rickey:
I am rather new at JS API development, so please forgive any ignorance on my part.
Your answer makes sense to me if you are modifying the CSS file for a local instance of the JS API. (I found these lines in ESRI's online version of the API, which I assume is read-only). However, if you are not using a local instance of the JS API, which CSS file are you operating on to apply these changes? Thank you for your time.
--NMM
@NateMurry_NOAA
How are you planning to deploy this? With a custom webapp? Like with the sample script you linked to?
