Hi Everyone,
I created a set of watersheds using a set of pourpoints raster, which have been snapped to the location of highest accumulation using the snap pourpoint tool and the Watershed tool. When I generated the watershed, one of the watersheds has void spaces within the watershed. I was wondering if anyone have faced this problem before and how you resolved it? I attached a picture of the watershed below.
Did you fill "sinks" before running the flow direction tool? Do you have a depressionless dem?
How Flow Direction works—ArcGIS Pro | Documentation
Creating a depressionless DEM—ArcGIS Pro | Documentation
After using the fill tool with the directional raster, there were six instances of sinks filled-in. However, the resulting dem raster is not located where the original dem is located but at Hudson Bay. I am wonder how I am using the fill tool incorrectly? Thanks for your help!
I suspect your map and input files and output file were in different coordinate systems, use the Environments tab on tools to make sure you get your coordinate systems correct
Good day
Used the d8 flow direction from a 5m dem to create the watershed, but it calculated only 1 bock or a small area around the stream. A can see the watershed must be a lot bigger with the stream data I have.
