Hello everyone,
Is there a way to change the text on the About Us widget directly on the generated code after the application gets exported to IIS
Thanks
@JoseSanchez
If you are taking about the "About" widget then you look in your apps configs folder and About folder and edit the config__#.json file.
Do you mean the About widget? If you go into the directory configs/About, you can modify the json file. In my app, it's named "config_widgets_About_Widget_20.json"
Thank you Ken and Robert,
Yes the About Us widget, I just found it under \configs\About
Thank you
