Yesterday, I started to get this error on my Android phone. I have the latest Field Maps and Collector app and my Android is fully updated. Not sure why I got this error today, after never receiving it... I have attached the screenshot from my phone.
@oakmn
I spent all morning dealing with this with Esri, an Esri partner we've contracted in the past who services Esri clients, a 3rd party vendor (who is also an Esri partner), and our IT department.
If you want the background to this here's an article describing what is happening: https://techcrunch.com/2021/09/21/lets-encrypt-root-expiry/
For an Android phone’s built-in browser, the list of trusted root certificates comes from the operating system — which is out of date on these older phones,” Let’s Encrypt explains. “However, Firefox is currently unique among browsers — it ships with its own list of trusted root certificates. This was a clue for us. Note the Sept 30th expiration.
Steps taken:
Current workaround (your experience will vary a bit depending on your android version(s) and what browser you use on your desktop; Firefox used here did not try with other browsers):
Manually install R3 cert to device
Click More Information
View Certificate
This fixed Collector and Field Maps but so far not the 3rd party Esri app. I expect this may have far reaching impacts for Esri Partner devs.
We're also having this issue. Is there any update here??
We have the same issue on android. Downloading the certificate from a browser and exporting/importing to android failed, since newer android versions ask for a private key which we do not have. How do we deal with this issue?
Application is working fine with IOS, only issue observed in android version
@MuhammadWaqar_ul_islam same for me....🤔
I am using Enterprise 10.9.1 and field map app and getting same error even installing pfx certificate on android device.
how to resolve this issue
@ZacharyHart Thanks a million! I followed your steps and Field Maps now works on my Android phone. I will have the other Android users download the cert and install it on their devices.
UPDATE: I have found that iPad and iPhone users within our organization are having the same problem.
Can't thank you enough!
I don't believe this is the case at all.
This message is displayed when your Portal and/or Server web adapters are configured with client certificate authentication (PKI). You do not appear to have any client certificates installed on your device which allow you to authenticate.
So you could check if anything changed related to the web-adapters.
If you try to access your organization in a web browser in incognito/private mode do you also get prompted for a certificate? If so, then this further points to a server configuration issue.
@Brooks_SummitGeo I have found out that everybody in our organization is having the same issue, it isn't just related to my device. Our IT/Server groups said there was no group policy changes....
@Brooks_SummitGeo Thanks for the reply!
The certificate is valid, so I guess I will have to speak with our network services group to see if there was group policy changes.
@oakmn are you the IT admin responsible for your domains certificates? Possibly need to renew? Or has a group policy update been applied to your organisations domain server?
