see my post: Multipatch
I read that document and like Allan I couldn't get it to work.
My successful effort was the sub below. I have used it to add images to the flags on the Sydney Harbour Bridge and the Anzac Bridge in Sydney. Sorry for the line nos, I forgot to strip them out.
Private Sub tileComponentGeometry(ByVal sLayer As String, ByVal sOID As String, _
ByVal sTextureFile As String, ByVal sGeomNo As String, _
ByRef sError As String, ByRef sMsg As String, ByVal sXfreq As String, _
ByVal sYfreq As String)
' Add an image to a component geometry. The image is tiled Xfreq x Yfreq across the geometry.
' sOID can only refer to one component. The image is in the texture file.
1: Using pComReleaser As New ESRI.ArcGIS.ADF.ComReleaser
2: Dim pColour As IRgbColor
3: Dim iColourNo As Integer
4: Dim pFeat As IFeature
5: Dim pFC As IFeatureClass
6: Dim pPtColl As IPointCollection4
7: Dim iOID As Integer
8: Dim pGeom As IGeometry
9: Dim bGeomProgress As Boolean
10: Dim pPt1 As ESRI.ArcGIS.Geometry.IPoint
11: Dim pWKSPt As WKSPoint
12: Dim pZAware As IZAware
13: Dim pExGeomCol As IGeometryCollection
14: Dim pExMultiPatch As IMultiPatch
15: Dim pNewGeomPatchCreator As IGeneralMultiPatchCreator
16: Dim pGenInfo As IGeneralMultiPatchInfo
17: Dim pMat As IGeometryMaterial
18: Dim pMatList As IGeometryMaterialList
19: Dim i As Integer
20: Dim iPatchType As ESRI.ArcGIS.Geometry.esriPatchType
21: Dim j As Integer
22: Dim k As Integer
23: Dim n As Integer
24: Dim iVertices As Integer
25: Dim pNewMultiPatch As IMultiPatch
26: Dim pSpatialRef As ISpatialReference
27: Dim sFldOID As String
28: Dim bWhere As Boolean = True
29: Dim iGeomCount As Integer
30: Dim iGeomNo As Integer
31: Dim iPatchCount As Integer
32: Dim iAction As m_eTextureAction = m_iTextureAction
33: Dim iVertexCount As Integer
34: Dim s As String = "s"
35: Dim pColTextureFiles As New StringCollection
36: Dim sTempTextureFile As String
37: Dim iFileIndex As Short = 0
38: Dim dTransparency As Double ' 0 to 1
39: Dim sFileDir As String = My.Application.Info.DirectoryPath
40: Dim pExMultiPatchCopy As IMultiPatch
41: Dim iNewTexture As Short
42: Dim hPatchMatII As New Hashtable ' Patch index and it's material index
43: Dim hTexturePts As New Hashtable ' Point index + texture pt
44: Dim hExistingTexturesII As New Hashtable ' Material No + nothing
45: Dim iPriority As Integer
46: Dim iGeomMatIndex As Integer ' The material index of iGeomNo
47: Dim bAssigned As Boolean = False ' Set to True if the texture is overwriting an existing texture
49: Dim iXfreq As Short
50: Dim iYfreq As Short
51: Dim iX As Short
52: Dim iY As Short
53: Dim iTotTextureVertexCount As Integer
54: Dim iTextureVertexCount As Integer
55: Dim iTexture As Integer
56: Try
57: sError = ""
58: sMsg = ""
' Only one component can be changed and at least one geometry must be specified.
59: If String.IsNullOrEmpty(sOID) OrElse IsNumeric(sOID) = False Then
60: sError = "One (and only one) Component must be chosen"
61: Exit Sub
62: End If
' Set the OID
63: iOID = CInt(sOID)
64: If String.IsNullOrEmpty(sGeomNo) OrElse IsNumeric(sGeomNo) = False Then
65: sError = "At least one Geometry must be chosen as a Geometry Number"
66: Exit Sub
67: End If
' Geometry No
68: iGeomNo = CInt(sGeomNo)
' X and Y frequency
69: If String.IsNullOrEmpty(sXfreq) Or String.IsNullOrEmpty(sYfreq) Then
70: sError = "A Row and Column tile frequency is missing"
71: Exit Sub
72: End If
73: If IsNumeric(sXfreq) = False Or IsNumeric(sYfreq) = False Then
74: sError = "The Row or Column tile frequency is not a number"
75: Exit Sub
76: End If
77: iXfreq = CInt(sXfreq)
78: iYfreq = CInt(sYfreq)
' Spatial Reference
79: pSpatialRef = m_pSxDoc.Scene.SpatialReference
' Layer FeatureClass
80: Call getLayerFC(sLayer, pFC, sError, m_hLayers)
81: If sError.Length > 0 Then
82: sError = "cmdLayerReColour;" & vbCrLf & sError
83: MsgBox(sError)
84: If g_bLogging = True Then g_wLog.WriteLine(Format(Now, "hh:mm:ss") & " " & sError)
85: Exit Sub
86: End If
87: pComReleaser.ManageLifetime(pFC)
88: sFldOID = pFC.OIDFieldName
' Get the geometries that make up the component and copy them with the
' old or the new colour/texture. Note that you cannot update these values in the
' existing multipatches.
89: pFeat = pFC.GetFeature(iOID)
90: StatusLabel1.Text = iOID.ToString
91: StatusStrip1.Refresh()
92: If pFeat.ShapeCopy.IsEmpty Then
93: sError = "EMPTY SHAPE"
94: sMsg = "Shape is empty for feature; OID = " & sOID
95: Exit Sub
96: End If
97: bGeomProgress = False
98: pExGeomCol = CType(pFeat.ShapeCopy, IGeometryCollection)
' Decide if a progressbar of geometry is required
99: iGeomCount = pExGeomCol.GeometryCount
100: If iGeomCount > MAX_GEOM_COUNT_IGNORE Then
101: bGeomProgress = True
102: ProgressBar1.Value = 0
103: ProgressBar1.Maximum = iGeomCount
104: End If
' Get the existing Multipatch and it's info
105: pExMultiPatch = CType(pFeat.ShapeCopy, IMultiPatch)
' Make a copy
106: Dim objectCopy As IObjectCopy = New ObjectCopyClass()
107: Dim obj As Object = objectCopy.Copy(CObj(pExMultiPatch))
108: pExMultiPatchCopy = CType(obj, IMultiPatch)
109: pComReleaser.ManageLifetime(pExMultiPatchCopy)
110: pGenInfo = pExMultiPatchCopy
' Get the relationship between the patches (geometries) and the materials
' and the material index of the chosen geometry
111: iTotTextureVertexCount = 0 ' The existing total texture vertex count. If the new tiles replace
' ' an existing texture then the count from that texture is omitted.
112: For i = 0 To pGenInfo.PatchCount - 1
113: j = pGenInfo.PatchMaterialIndex(i)
114: hPatchMatII.Add(i, j)
115: If i = iGeomNo Then
116: iGeomMatIndex = j
117: iTotTextureVertexCount += (iXfreq * iYfreq) + 4 ' Add top left + bottom rt texture pts
118: ElseIf pGenInfo.IsMaterialTextured(j) = True Then
119: iTotTextureVertexCount += pGenInfo.PatchTextureVertexCount(i)
120: End If
121: Next i
' MultiPatch Info
122: iVertices = pGenInfo.VertexCount
123: iPatchCount = pGenInfo.PatchCount
' Create the new materials as a copy of the existing ones
124: pMatList = New GeometryMaterialListClass
125: For i = 0 To pGenInfo.MaterialCount - 1
126: pMat = New GeometryMaterial
127: If i = iGeomMatIndex And pGenInfo.IsMaterialTextured(i) = True Then
' Replace the old with the new texture - no colour
128: pMat.TextureImage = sTextureFile
129: iNewTexture = i
130: bAssigned = True
131: Else
' Existing Texture
' Colour
132: iColourNo = pGenInfo.MaterialColor(i)
133: pColour = New RgbColor
134: pColour.RGB = iColourNo
135: pMat.Color = pColour
136: If pGenInfo.IsMaterialTextured(i) = True Then
137: hExistingTexturesII.Add(i, i)
' Save an image of the texture
138: sTempTextureFile = sFileDir & "\" & TEXTURE_TEMP_FILE & iFileIndex.ToString & ".jpg"
139: If IO.File.Exists(sTempTextureFile) Then
140: IO.File.Delete(sTempTextureFile)
141: End If
142: StatusLabel1.Text = "OID " & sOID & " reading Texture No " & i.ToString
143: StatusStrip1.Refresh()
144: Call textureImageCreate(pGenInfo, i, sTempTextureFile, sError)
145: If sError.Length > 0 Then
146: sError = "tileComponentGeometry;" & vbCrLf & sError
147: Exit Sub
148: End If
' Add the file to the list so it can be deleted later
149: pColTextureFiles.Add(sTempTextureFile)
150: pMat.TextureImage = sTempTextureFile
151: iFileIndex += 1
152: End If
' Transparency
153: dTransparency = pGenInfo.MaterialTransparencyPercent(i)
154: pMat.Transparency = dTransparency / 100
155: End If
156: pMatList.AddMaterial(pMat)
157: Next i
158: If bAssigned = False Then
' Add the new material to the material list - no colour
159: iNewTexture = pMatList.Count
160: pMat = New GeometryMaterial
' New texture
161: pMat.TextureImage = sTextureFile
162: pMatList.AddMaterial(pMat)
163: End If
' Start the MultiPatch creator for the geometry copy
164: pNewGeomPatchCreator = New GeneralMultiPatchCreatorClass
165: pNewGeomPatchCreator.Init(iVertices, iGeomCount, False, False, False, iTotTextureVertexCount, pMatList)
' Set the patch types, points, materials and start points for vertices and textures
166: k = 0 ' Vertex
167: n = 0 ' Vertex
168: iTexture = 0 ' Vertex
169: For i = 0 To iGeomCount - 1
170: iPatchType = pGenInfo.PatchType(i)
171: iVertexCount = pGenInfo.PatchVertexCount(i)
172: iTextureVertexCount = pGenInfo.PatchTextureVertexCount(i)
' Patch Type
173: pNewGeomPatchCreator.SetPatchType(i, iPatchType)
' Patch No set start of next patch
174: pNewGeomPatchCreator.SetPatchPointIndex(i, k)
' Patch Material
175: If i = iGeomNo Then
176: pNewGeomPatchCreator.SetMaterialIndex(i, iNewTexture)
177: Else
178: pNewGeomPatchCreator.SetMaterialIndex(i, hPatchMatII(i))
179: End If
' Patch priority
180: iPriority = pGenInfo.PatchPriority(i)
181: pNewGeomPatchCreator.SetPatchPriority(i, iPriority)
' Texture point indexes
'pNewGeomPatchCreator.SetPatchTexturePointIndex(i, n)
' Set the texture vertex pts
182: If i = iGeomNo Then
183: pNewGeomPatchCreator.SetPatchTexturePointIndex(i, iTexture)
'' Set the top left and bottom right texture pts
'pWKSPt = New WKSPoint
'pWKSPt.X = 0
'pWKSPt.Y = iYfreq
'pNewGeomPatchCreator.SetTextureWKSPoint(iTexture, pWKSPt)
'iTexture += 1
'pWKSPt.X = iXfreq
'pWKSPt.Y = 0
' Left
184: For iY = 0 To iYfreq
185: pWKSPt = New WKSPoint
186: pWKSPt.X = 0
187: pWKSPt.Y = iY
188: pNewGeomPatchCreator.SetTextureWKSPoint(iTexture, pWKSPt)
189: iTexture += 1
190: Next iY
' Top
191: For iX = 0 To iXfreq
192: pWKSPt = New WKSPoint
193: pWKSPt.X = iX
194: pWKSPt.Y = iY
195: pNewGeomPatchCreator.SetTextureWKSPoint(iTexture, pWKSPt)
196: iTexture += 1
197: Next iX
' Right
198: For iY = iYfreq To 0 Step -1
199: pWKSPt = New WKSPoint
200: pWKSPt.X = iX
201: pWKSPt.Y = iY
202: pNewGeomPatchCreator.SetTextureWKSPoint(iTexture, pWKSPt)
203: iTexture += 1
204: Next iY
' Bottom
205: For iX = iXfreq To 0 Step -1
206: pWKSPt = New WKSPoint
207: pWKSPt.X = iX
208: pWKSPt.Y = iY
209: pNewGeomPatchCreator.SetTextureWKSPoint(iTexture, pWKSPt)
210: iTexture += 1
211: Next iX
212: ElseIf hExistingTexturesII.ContainsKey(pGenInfo.PatchMaterialIndex(i)) Then
213: pNewGeomPatchCreator.SetPatchTexturePointIndex(i, iTexture)
' This geometry has an existing texture. Reallocate the points
214: For j = 0 To pGenInfo.PatchTextureVertexCount(i) - 1
215: pWKSPt = New WKSPoint
216: pWKSPt = pGenInfo.PatchTextureVertex(i, j)
' Add this point
217: pNewGeomPatchCreator.SetTextureWKSPoint(iTexture, pWKSPt)
218: iTexture += 1
219: Next j
220: End If
' ***** Set the geometry points *****'
' Point collection type
221: iPatchType = pGenInfo.PatchType(i)
222: Select Case iPatchType
Case esriPatchType.esriPatchTypeTriangleStrip
223: pPtColl = New TriangleStripClass
224: Case esriPatchType.esriPatchTypeTriangleFan
225: pPtColl = New TriangleFanClass
226: Case esriPatchType.esriPatchTypeTriangles
227: pPtColl = New TrianglesClass
228: Case Else
229: pPtColl = New RingClass
230: End Select
231: pGeom = pExGeomCol.Geometry(i)
232: pPtColl = CType(pGeom, IPointCollection4)
233: For j = 0 To pPtColl.PointCount - 1
234: pPt1 = New ESRI.ArcGIS.Geometry.Point
235: pZAware = pPt1
236: pZAware.ZAware = True
237: pPt1 = pPtColl.Point(j)
238: pNewGeomPatchCreator.SetPoint(n, pPt1)
' Texture
'pNewGeomPatchCreator.SetTexturePoint(n, pPt1)
239: n += 1
240: Next j
241: If bGeomProgress = True Then ProgressBar1.Value = i
' User hits stop button
242: System.Windows.Forms.Application.DoEvents()
243: If m_bStop = True Then
244: sMsg = "Aborted by user"
245: Exit Sub
246: End If
'pNewGeomPatchCreator.SetPatchTexturePointIndex(i, k)
247: k += iVertexCount
248: Next i
249: pNewMultiPatch = New MultiPatch
250: pNewMultiPatch.SpatialReference = pSpatialRef
251: pNewMultiPatch = pNewGeomPatchCreator.CreateMultiPatch
252: pFeat.Shape = pNewMultiPatch
253: pFeat.Store()
254: pNewGeomPatchCreator.ClearResources()
255: Marshal.ReleaseComObject(pFeat)
256: Marshal.ReleaseComObject(pExMultiPatch)
257: Marshal.ReleaseComObject(pNewMultiPatch)
258: Catch ex As Exception
259: sError = "ERROR: tileComponentGeometry; Line: " & Erl() & vbCrLf & "Layer " & sLayer & " OID = " & iOID & vbCrLf & ex.ToString
260: Finally
261: ProgressBar1.Visible = False
' Delete the texture files
262: If pColTextureFiles.Count > 0 Then
263: For Each sTempTextureFile In pColTextureFiles
264: Try
265: IO.File.Delete(sTempTextureFile)
266: Catch ex As Exception
267: If g_bLogging = True Then g_wLog.WriteLine(Format(Now, "hh:mm:ss") & " Error deleting file: " & sTempTextureFile & " " & ex.Message)
268: End Try
269: Next sTempTextureFile
270: End If
271: End Try
272: End Using
End Sub
I'm trying to make a fairly simple multipatch with an image textured onto it. The multipatch is basically made from a line with an upper and lower set of Z values. Creating the multipatch isn't a problem, the problem comes when I try to texture it. I've read some example code:http://edndoc.esri.com/arcobjects/9.2/NET/D773962D-2B32-4459-BB3F-376D2F6DE82F.htmhttp://edndoc.esri.com/arcobjects/9.2/ComponentHelp/esri3DAnalyst/IGeneralMultiPatchCreator_Example.htm Which gives me a general idea, but neither code sample or the documentation gives me a good enough idea on how the interfaces work. I need the image to stretch across the whole of the multipatch, but I can't quite work out what combination of values to feed in to make this happen. The SetTextureWKSPoint calls really don't make any sense to me, I'm not sure what the parameters actually mean. Does anyone have a simple code sample or a better explanation on what the calls in the IGeneralMultiPatchCreator interface actually mean? Thanks.
