I m trying to use the autocomplete function in storymap journal but I cannot figure out where to add the script. Any idea?
Hi.
Could you expand a bit on what you are hoping to do.
Rupert
I am currently using JQueryUI autocomplete to type project names and navigate to the section corresponding to that project.
I have it working almost working 100% but sometimes JQuery UI does not load up.
Is there a way to load it up in custom-script.js for instance?
I loaded it up via index.html
<SPAN class="doctype token"><SPAN><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fwww.w3.org%2FTR%2Fxhtml1%2FDTD%2Fxhtml1-transitional.dtd" target="_blank">http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd</A><SPAN>"></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>html</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>head</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN> <SPAN class="attr-name token">src</SPAN><SPAN class="attr-value token"><SPAN class="punctuation token">=</SPAN><SPAN class="punctuation token">"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=https%3A%2F%2Fcode.jquery.com%2Fui%2F1.12.1%2Fjquery-ui.js" target="_blank">https://code.jquery.com/ui/1.12.1/jquery-ui.js</A><SPAN class="punctuation token">"</SPAN></SPAN><SPAN class="punctuation token">></SPAN></SPAN><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN> <SPAN class="language-javascript script token"><SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"><</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN>document<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">ready</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> availableTags <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Mosquito Rd"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"1"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Peavine Ridge Rd"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"2"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Cable Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"3"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Grizzly Flat Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"4"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"String Canyon Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"5"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Sciaroni Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"6"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Fort Jim Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"7"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Kyburz Drive"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"8"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Starkes Grade Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"9"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"White Meadows Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"10"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Pony Express Trail"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"11"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Cosumnes Mine Road (Loc 1)"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"12"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Cosumnes Mine Road (Loc 2)"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"13"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Cosumnes Mine Road Bridge"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"14"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Happy Valley Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"15"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Sweeney Road Bridge"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"16"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Tahoe Roads"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"17"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Evelyn Way"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"18"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Fallen Leaf Road/Tahoe Mountain Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"19"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Lakeview Avenue"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"20"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Mt. Aukum Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"21"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Bucks Bar Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"22"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Newtown Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"23"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Airport Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"24"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Green Valley Road"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"25"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Lake Tahoe Boulevard"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"26"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Elks Club Drive"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"27"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"US 50/Missouri Flat Interchange, Phase 1B2 - Class 1 Trail"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"28"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"US 50/Missouri Flat Interchange, Phase 1C - Riparian Restoration"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"29"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Blair Road Bridge Replacement"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"30"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Ice House Road and Jones Fork Bridge Rehabilitation"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"31"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Green Valley Road at Weber Creek Bridge Replacement"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"32"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Meyers Stream Environment Zone/Erosion Control Project"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"33"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Diamond Springs Parkway, Phase 1A"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"34"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"New York Creek Class 1 Trail, Phase 2"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"35"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Sly Park Road at Clear Creek Bridge Replacement"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"36"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Silver Fork Road Bridge Rehabilitation"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"37"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"El Dorado Trail - Los Trampas to Halcon"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"38"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Silva Valley Parkway - Class 1 and 2 Bike Trails"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"39"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Francisco Drive/Schooner Way ADA Improvements"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"40"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Elks Club Drive Overlay"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"41"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> label<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Country Club Heights Erosion Control Project"</SPAN><SPAN class="punctuation token">,</SPAN> value<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"42"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#tags"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">autocomplete</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> source<SPAN class="punctuation token">:</SPAN> availableTags<SPAN class="punctuation token">,</SPAN> select<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">,</SPAN> ui<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> event<SPAN class="punctuation token">.</SPAN><SPAN class="token function">preventDefault</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#results"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN>ui<SPAN class="punctuation token">.</SPAN>item<SPAN class="punctuation token">.</SPAN>value<SPAN class="punctuation token">)</SPAN> <SPAN class="token function">$</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"#tags"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">val</SPAN><SPAN class="punctuation token">(</SPAN>ui<SPAN class="punctuation token">.</SPAN>item<SPAN class="punctuation token">.</SPAN>label<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token tag"><SPAN class="token tag"><SPAN class="punctuation token"></</SPAN>script</SPAN><SPAN class="punctuation token">></SPAN></SPAN></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Our apps rely on Dojo's AMD module loader to load additional JavaScript files (or bundle them for production). Full documentation about the loader is available here: The Dojo Loader — The Dojo Toolkit - Reference Guide. I found this page that may also be helpful: https://learn.jquery.com/jquery-ui/environments/amd/.
Looking at this site https://learn.jquery.com/jquery-ui/environments/amd/ . It seems like exactly what I need. However, I am unsure how to achieve this in a story map Journal. I would like to use it in the "custom-script.js". It is using a "define", not "require".
Define and require are very similar and in your case, should be able to be used in the same way: The Dojo Loader — The Dojo Toolkit - Reference Guide.
With AMD loading, we only load the JavaScript modules we need when we need them. Most of the modules are from the JavaScript API so that is the default location. We specify a few other folders to load files from in the app: storymap-journal/main-config.js at master · Esri/storymap-journal · GitHub. The app folder is one of these location so you can include the necessary files under the app folder and reference it with the app prefix: 'app/jquery-ui/autocomplete'.
Thanks Stephen,
That makes sense.
I just refenced the autocomple.js in the define using 'app/jquery-ui/autocomplete', this in the custom-script.js file.
Now I am getting these errors:
Any idea, should it be defined somewhere else than the custom script?
