I am using QT verion 5.14.2 and arcgis version 100.8.
I want to create a widget application which can display routes on my 2D map. I need to add navigational features to my widget . I have gone through arcgis documentation and learnt that I might need to work on ArcGIS Pro to generate a Mobile Map Package geoprocessing tool, with the map and network dataset. My query is that is it possible to generate this data out of .shp files and use a topographic map rather than a geodatabase and network dataset?? Or is it necessary to generate a map through ArcGIS Pro??
