Does the Identify widget version 2.2.2 support layers publishedfrom Arc Server 9.31? I am guessing it doesn't, I can not getthe popup window to display my field information.Does the widget work with feature layers only?
Shannaka, Not sure I understand the question can you be more specific?
Shannaka, I am on my way to the developer summit in California, but I will put something together soon. Are you thinking a public variable that you can call from in this widgets code or what are you thinking.
public var selRelateURL:String; //Then add this line to the closeRelateWindow after the flyToSearch is set selRelateURL = flyToSearch.url.substring(0,flyToSearch.url.lastIndexOf("/")) + "/" + (rWindow.selectedRelateId - 1);
public function get selectedTableId():Number { return _rTableId; } protected function relateGrid_itemClickHandler(event:ListEvent):void { _rId = event.target.selectedItem.id; _rName = event.target.selectedItem.name; _rTableId = event.target.selectedItem.relatedTableId;
<layername>Water Gauges</layername>
<layername>Stations</layername>
Hi Robert, I have a problem that I am hoping that youâ??ll be able to help me with. First, I really appreciate your identify widget. It is a fantastic tool, with exactly the functionality that I am looking for. Also, please know that your tremendous support for this tool is very much appreciated. Initially, I want to use the tool for a very simple popup window with a hyperlink. Eventually, I want to use the full functionality of the tool. As a starting point, using the sample data provided, I simplified the tool through modifications to the config-infoimage.xml and IWT_Cameras.xml files for the AttRelateInfoWinWidget and the Louisville/LOJIC_PublicSafety_Louisville data. Everything worked as expected. After that, while trying to use my own data, I am totally stuck. I have scoured this formum as well as many of the other forums and have found some great information but I still canâ??t get past my problem. I am unable to get the widget to operate with my operationallayers layer. The basemap comes up fine but the operational layer does not display. If I use the operational layer as a basemap it will display find so I know the server is publishing the data properly. I am using ArcGIS Server 10 Identify widget 2.2.1 The ArcGIS viewer code Flash builder 4 I have implemented crossdomain.xml on the server I am working from my Home Computer accessing the server data I have republished my data in a file geodatabase rather than a shapefile My operational layer is in the same coordinate system as the base layer Your help on this problem will be greatly appreciated. Hereâ??s the code for my Config.xml: <?xml version="1.0" ?> <configuration> <title>Attachment Relate Info Window Widget Sample</title> <subtitle>Preview of attachment relate info window Widget for FlexViewer 2.2</subtitle> <style> <colors>0xFFFFFF,0x333333,0x101010,0x000000,0xFFD700,0x000000</colors> </style> <bing key="Al0VE_jsmagxk4LFghXGlK5JSHfC0tk-eHRubZv_eMYm6wzgQaStYks8g-wWcgk3"/> <widget left="10" top="50" config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/> <widget left="0" top="0" config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/> <map initialextent="2161043 7283519 2856700 7679584" top="40"> <basemaps> <layer label="Topo Map" type="dynamic" visible="true" alpha="1" url="http://198.164.148.17/ArcGIS/rest/services/Flood_Jan_2011_SNB/MapServer"/> <operationallayers> <layer label="Water Gauges" type="dynamic" visible="true" alpha="1" info="widgets/InfoTemplates/AttRelateInfoWinWidget.swf" infoconfig="widgets/InfoTemplates/Sam_data.xml" url="http://198.164.148.17/ArcGIS/rest/services/Gauges_05/MapServer/0"/> <identifylayeroption>visible</identifylayeroption> </operationallayers> </basemaps> </map> <widgetcontainer /> </configuration> Here is the code for my widget configuration xml file: <?xml version="1.0" ?> <configuration> <fields>Gauge_URL,Name</fields> <titlefield>Name</titlefield> <links> <linkfield icon_or_text_or_img="text" icon="" linkalias="Go To Graphs..." linkprefix="" linksuffix="">Gauge_URL</linkfield> </links> <multiimagefield linkprefix="" linksuffix="" nexttooltip="Next" prevtooltip="Prev"></multiimagefield> <layername>Water Gauges</layername> <zoomscale>5000</zoomscale> <csvseparator>,</csvseparator> <labels> <csvdefaultname>Related Records</csvdefaultname> <exportbtnlabel>Export...</exportbtnlabel> <export2csvoptionlabel>Export to CSV...</export2csvoptionlabel> <export2txtoptionlabel>Export to Txt...</export2txtoptionlabel> </labels> </configuration>
<?xml version="1.0" ?> <configuration> <title>Attachment Relate Info Window Widget Sample</title> <subtitle>Preview of attachment relate info window Widget for FlexViewer 2.2</subtitle> <style> <colors>0xFFFFFF,0x333333,0x101010,0x000000,0xFFD700,0x000000</colors> </style> <bing key="Al0VE_jsmagxk4LFghXGlK5JSHfC0tk-eHRubZv_eMYm6wzgQaStYks8g-wWcgk3"/> <widget left="10" top="50" config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/> <widget left="0" top="0" config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/> <map initialextent="2161043 7283519 2856700 7679584" top="40"> <basemaps> <layer label="Topo Map" type="dynamic" visible="true" alpha="1" url="http://198.164.148.17/ArcGIS/rest/services/Flood_Jan_2011_SNB/MapServer"/> </basemaps> <operationallayers> <layer label="Water Gauges" type="feature" visible="true" alpha="1" info="widgets/InfoTemplates/AttRelateInfoWinWidget.swf" infoconfig="widgets/InfoTemplates/Sam_data.xml" url="http://198.164.148.17/ArcGIS/rest/services/Gauges_05/MapServer/0"/> </operationallayers> </map> <widgetcontainer /> </configuration>
var data:Object = { id: String(this.widgetId), url: infoUrl, config: "widgets/InfoTemplates/IWT_Projects.xml" };
Hi,I'm having trouble getting this to work with the query widget. It gets a heading for the info window but none of the fields and no relates or attachments are shown. I've set the info template <info>widgets/InfoTemplates/AttRelateInfoWinWidget.swf</info> in the query .xml and the info config file in the mxml:var data:Object = { id: String(this.widgetId), url: infoUrl, config: "widgets/InfoTemplates/IWT_Projects.xml" };The info config file works on the layer if I use it without the query widget. Has anyone tried this and got it to work or know of any reason why this wouldn't work?Cheers,Shannaka
Can you export to an .MXD and open in ArcMap?Thanks.
