All, These widgets are now released. Don't forget to rate them and let me know what you think. Then starting February 21st don't forget to vote.Route Widget link:http://www.arcgis.com/home/item.html?id=992b1f691f44489aa4dcbafe2db66700Attribute Relate Info Window Widget:http://www.arcgis.com/home/item.html?id=4ec33120c9ea4d019fddf722fc34ea3c
KF BONG, No, there is no others that I am aware of. It sounds like you just have some issues with ArcGIS Server publishing the related tables probably permissions issues. I would call tech support and get guidance or post to the Server General forum.
<bing key="Al0VE_jsmagxk4LFghXGlK5JSHfC0tk-eHRubZv_eMYm6wzgQaStYks8g-wWcgk3"/>
Hi RobertWhen i use the relate-info, and the related table has dates in it, it shows up like a string of numbers, and not a date - see wrong-date-format.pngis it me doing something wrong, cause you also has it in your preview-site, see wrong-date-format-robert.jpgbut else nice widgets...Mads GrenLemvig KommuneDenmark
...replace the standard bing key with one from your ArcGIS Server in the config.xml for your site
Do you know if there is any plans to update more of the ArcGIS Online servers to showcase the ArcGIS Server 10 capabilities, like single line geocoding?
hi Robert,Currently, are you able to configure hyperlink field inside the related tables? I didn't see that in the xml config file and in the live example. Please do consider this enhancement if not available yet.Thanks,KF
