I have my Add-In on ArcGIS Pro under which I have 4 buttons. So, now I want if I click on any button I want rest of the button get disabled. Until I close the current page.
ArcGIS Pro SDK 2.8 VS2019
I think the easiest way to do this is to use the condition. Set the condition in the config.daml file for your buttons. Then in the code, you can control the state of the condition. There are examples of how to do this in the AGP Wiki (a great resource to use as it answers A LOT of questions you might have).
Kris
Can you share any links?
Here is the link to the ArcGIS Pro SDK wiki
Home · Esri/arcgis-pro-sdk Wiki · GitHub
This Pro Guide (it's in the Wiki Kris mentioned above) shows how to make your own states & conditions:
ProGuide Code Your Own States and Conditions · Esri/arcgis-pro-sdk Wiki (github.com)
Hi @TapasChakrabarty ,
On top of states and conditions, you can use this code to enable/disable the button from the ribbon bar.
ProGuide Code Your Own States and Conditions · Esri/arcgis-pro-sdk Wiki · GitHub
FrameworkApplication.GetPlugInWrapper("your button id in daml").Enabled = false;
Hi, thanks for this tip. In my use case, this FrameworkApplication.GetPlugInWrapper("your button id in daml").Enabled = false; is complaining about being a read only property ... Any ideas?
Thanx in advance!!
