HI ,
I am new in ArcGis . I want to build a portal that allow to search facilities in school and display location in the map .
https://www.map.gov.hk/gm/map/search/faci/__COVID19API_CVCTYPE1
Can I anyone share idea how to build it ?
Thanks
Hi Felix,
1. You will need the location/spatial data of the facilities that you would like the users to visualize on the map.
2. Let consider if you have the list of the locations with coordinates (lat,long or X,Y, etc) in spatial format (shapefiles, geodatabases or CSV)
3. Use this data to be added as feature layer in the ArcGIS environment, in this case I am assuming that you have an existing ArcGIS Online subscription you may publish the data as hosted feature layer.
4. Create a web map with the feature layer created earlier and configure the symbology and additional pop up info.
5. Create web application using configurable applications such as ArcGIS Dashboard or Web App Builder and create web app.
6. Set necessary access and capabilities.
Tada, your app is ready to be shared with users.
Hi Manish,
I am a new user . DO you have example to create location/spatial data ?
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
