I'm developing a file geodatabase schema and I noticed that my domains are sorted alphanumerically in the Attribute Table pull-down menus, but they are in my desired order in the Domains view. Please do not force the order to be alphanumeric.
This also applies to the Select by Attributes command. You are essentially making a decision that alphanumeric is better than what the database administrator set in the domain for the order of the coded values. In addition, I seconded the ideas for providing more options to manipulate the domain order in the Domains view.
This was noted as https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDA5ODIxMw== which is showing as fixed in ArcGIS Pro 2.9 - so updating this status to In Product Plan.
For the comment about Select by Attributes - here is what I see in 2.7.3:
Here is what I see in a dev build of 2.9:
As noted in previous comments, this was treated as a bug rather than an idea, which allowed for it to be addressed in a patch. This is fixed in ArcGIS Pro 2.8 Patch 2 (2.8.2).
Select by Attributes:
Melden Sie sich an, um zu posten, Inhalte zu folgen und mehr. Neu hier? Kostenlos registrieren.
