Apple M1 Running ArcGIS Pro and Desktop as follows1. Apple iMac M1- https://www.apple.com/imac-24/2. Parallels (Install parallels on M1 Computer)- https://kb.parallels.com/en/1250383. Windows Insider preview ARM 64 (Install Windows- https://www.microsoft.com/en-us/software-download/windowsinsiderpreviewARM644. Install ArcGIS Pro and/or Desktop on Windows VM
Got this running today. I had to install dotnet 6.0 x64 (NOT arm64) runtime in the Parallels Windows 11 instance, but it works just fine. I have parallels giving 4x cpu and other resources on demand. I am running it on a M1 macbook pro with 32 cores and 32gb ram. And while the performance would probably be better using arm architecture all the way down (This is a reality I think Esri will eventually have to get on board with), it is certainly usable.
Which CPU architecture did you download for dotnet? If you chose the arm64 version, that is likely why it's failing to start. If so, uninstall that and try the x64 version. I'm on Parallels 17, Windows 11 ARM on Macbook Pro M1 Max, ArcGIS Pro 3.0, running great.
I had to install .net 6 x64 version, i think it tried to use arm64 one
In your windows arm, have you download all .net library? Pro is base on .Net so just download it in windows and why not to the Mac itself.
Same here, win 11 arm, arcgis pro failing to start...here's the msg from event viewer:
"Failed to load the dll from [C:\Program Files\dotnet\host\fxr\6.0.7\hostfxr.dll], HRESULT: 0x800700C1
The library hostfxr.dll was found, but loading it from C:\Program Files\dotnet\host\fxr\6.0.7\hostfxr.dll failed
- Installing .NET prerequisites might help resolve this problem."
Hello @AMoyers and @MatthiasEbert , I will try to replicate your scenarios afresh.Sean.
I have exactly the same issue. could you solve the problem?
@SeanAdlai I have just bought an M1 Mac and I've been trying to get ArcGIS Pro to run on it, but it won't open. According to your experience, if the install goes as planned and proper dependencies are in place it should install regularly and run out of the box on Parallels with Windows ARM, correct? I have Parallels 17 with Windows 11 ARM and ArcGIS Pro, the first time I ran the installer I got messages about missing runtimes which I installed. The second time I ran the installer it completed the install but will not open at all (don't see any "thinking" or background processes that have initiated either). Anyone have any thoughts?
Thank you. I appreciate your help and confirmation.
Hi Kendrick,
Yes and no. You have to purchase parallels to be able to run windows. But, for now, Window arm is not available to purchase. Look at the tread of Sean. You have to register for preview insider then download, windows for testing.
Like said, in future, Microsoft will, maybe, sell windows arm but not for now.
Thanks for the review and information. Looking to purchase the MBP with M1 and want to be certain I understand how to install. I am unclear on where and how (and precisely what) to download Windows OS. Does it have to be purchased separately? (Assuming I will be installing Parallels Desktop® 17 forMac??)
Maybe, not so far away, Windows arm will be available, legally. If ESRI can than compile Pro for arm...
https://www.xda-developers.com/qualcomm-exclusivity-deal-microsoft-windows-on-arm/
Works great! No issues so far.
I noticed on esris website it states ArcPro can't run without an intel processor? Has the M1 chip worked well for you?
Parallels and VMware aren't emulators. What these programs does : making many os on the same machine.
So, since M1 are ARM, you need ARM os. With arm Windows, not officially release, you could make win running in parallel with macOs. Microsoft could anytime stop letting us download this test version or maybe sell arm win to all. Nobody can predict it.
To be clear, parallels work with windows arm.
Then, the second stage. The programs inside each OS. We know that macOs arm have rosetta 2 to make legacy intel program running with, to be fare, very good speed. In windows arm, you have something like that to run intel programs. Do the window emulator is as good as Mac one?
Remember last change of os with rosetta. Apple leave it for a few years to make the transition and after that. No more support. What will be the futur of Win intel emulator?
So, for the time being, it's work but do the emulator, inside win, work with all aspect of arcgis request?
Is the newest Parallels working with Windows or Windows ARM on M1? Its unclear for me if it runs the ARM version or the normal one. Is VMware running on M1 and can I use it to run a normal windows there?
The problem is not ARM to stay and Parallels. The problem is, Microsoft haven't release an official arm win. So what's the future? Who knows?
So, if it's to play with, fine. But, if you have limited $$$$ and really ned to use ArcGis Pro and others win program, I would play safe for now and stay with limited power of intel.
If you have the $$$ to have a second computer in case, so why not.
Good question.
Short answer - It works.
Caveat - longevity and support in question.
My thoughts - M1.and ARM are here to stay. Parallels is unparalleled in supporting MAC’s growing environments.
Don't by M1 if you're not willing to take risk. If you really need, for a few years to work with ArcGis and other specific Intel base program and don't have the budget to buy a PC if it's not working as expected on M1. Real hardware is sometimes tricky but emulation is not always perfect.
If you want a Mac, go for Intel base. With this, you will be able to remove the stress and in a few years, who knows, maybe Microsoft will release an official arm windows and maybe (I'm sure not) Esri will compile Pro to arm processors.
I´m lookig forward to buy a new MacBook Air to study and i need ArcGis and MS Access for it. So i can run both of them on MacOS if i use Parallels or Bootcamp? I´m asking again because i read different things about this topic.
Hello RatulGreat questions.- The M1for long-term prospects - Right performance but RiskyThe 8GB iMac performed within range. 16GB Macbook Pro test had Parallels issue.Will let you know when I try a 16GB iMac.BUT - A number of users make the valid point of at least waiting to see Microsoft's commitment ... etc.- MacBook Pro 32 GB for heavy spatial analysisI have actually tried with VMWare (Not bootcamp). Fast machine, but bad on GPU intensive tasks.Last I checked, neither VMWare nor Parallels took full advantage of GPU on Mac running windows.
Your best bet is convincing Apple that ESRI can be a worthy partner to make their maps better :-).Hope that helps.
Could anyone please tell me can I run heavy spatial analysis smoothly on a 13.3-inch MacBook Pro Apple M1 Chip with 8‑Core CPU 8‑Core GPU - Space Gray (16 GB/1 TB) using parallels + Windows Insider preview ARM 64?
I am truly confused and need suggestions. Thanks in advance.
Interesting result on Level 2! My macbook air with similar specs was much slower, but I wondered at the time if that was impacted by passive cooling and thermal throttling. The iMac was faster by 7 minutes!
Thanks for the guidance Peter.
Results for iMac M1, Parallels, Windows ARM64- Sharing - 4GB and 4 Cores(This would be a below spec windows machine)PAT Test Summary below.Level 1 Test (In spec, Below avg)- Expected Range - 2.5-3.3, Avg - 2.8- Result - 3.164Level 2 Test (In spec, Below avg)- Expected Range - 4 - 15, Avg - 8- Result - 11.122Level 3 Test (Out of spec)- Expected Range - 10-39, Avg - 20- Result - 46.776
Next steps- Testing a 16GB M1 with 8/12GB VM.
Thanks for sharing your testing results! (I think some of the elapsed times are missing for individual test steps in what you've shared, like the Analysis step?)
GIS can be used in a variety of ways, so it is usually a question of interpreting the results in the context of your own specific workflows. For example, if you have a basic GPU, then it will likely score poorly on the 3D performance tests relative to a powerful GPU. However, if you're not doing the kind of GIS work that needs a powerful GPU, then it can still be a passing score for your use case.
As mentioned in the blog post, the cumulative time it takes to run each test level provides an overall indication of ArcGIS Pro performance on the hardware.
For each test level you run, there should be a summary file (e.g., SUMMARY_Level1.log) which includes a Total Elapsed Time value. That value can be compared to the ranges in the table in the blog post. Or, if you use the run-all test script, then it will produce a CSV file that nicely summarizes each level's elapsed time in one place, which you can then compare to that table.
Thanks Peter.Tool ran fine.The instructions about how to compare them are not clear to me.- Maybe that portion can be more simply stated.In any case, here are results.
STARTUP
ArcGIS Pro Metrics
--- Fixed Metrics ---
CIMReadCounter = 19
CIMUpdateCounter = 0
CurrentDLLCount = 384
CurrentLocalDLLCount = 190
CurrentMemoryUsage = 1458704384
CurrentThreadCount = 83
HTTPRequestCancelCount = 0
HTTPRequestCount = 25
LicenseTime = 00:00:09.1959835
StartupDLLCount = 253
StartupLocalDLLCount = 93
StartupMemoryUsage = 299933696
StartupThreadCount = 48
StartupTime = 00:00:19.6589809
TotalBlockedTime = 0
TotalHungTime = 23500
TotalPaneConstructTime = 9094
TotalRequestCancelCount = 0
TotalRequestCount = 276
TotalTaskTime = 0
UICIMReadCounter = 221
UICIMUpdateCounter = 9
--- Named Metrics ---
Startup:Initialize_and_process_DAML = 2572
Startup:ShowWindow = 850
Startup:Wait_for_licensing = 8420
Startup:Initialization_complete = 8403
ProjectLoad:InternalOpenProjectAsync = 7907
ProjectLoad:InternalOpenMap = 1641
ProjectLoad:CreatePane_Instance1 = 9094
Execution Complete
PerfTools Script Execution Time = 00:00:00.5861415
==================ANALYSIS06/01/2021 07:45 STDOUT INFO Test: Analysis_GnatcatcherWorkflow
06/01/2021 07:45 STDOUT INFO 2.8.0.29751
06/01/2021 07:45 STDOUT INFO Setup successful
06/01/2021 07:45 STDOUT INFO =====Buffer successful=====
06/01/2021 07:45 STDOUT INFO Buffer: 2.122
06/01/2021 07:45 STDOUT INFO =====Select Layer by Attribute successful=====
06/01/2021 07:45 STDOUT INFO Select Layer by Attribute: 0.058
06/01/2021 07:45 STDOUT INFO =====Pairwise Erase successful=====
06/01/2021 07:45 STDOUT INFO Pairwise Erase: 1.147
06/01/2021 07:45 STDOUT INFO =====Intersect successful=====
06/01/2021 07:45 STDOUT INFO Intersect: 4.617
EDITING
Bookmark, Map, DrawTime, AverageFPS, MinimumFPS, FPSSamples, TimeStamp
3D Plan View, Rooftop Scene, 00:00:13.9951989, 68.3395531832318, 26.0217417129315, 128, 2021-06-01T11:59:30.2454719Z
Task: Draw Polyline Fence
EditFeatureLayer::
Map:"Rooftop Plan"
RegistrationType:"Nonversioned"
ShapeType:"Polyline"
Dimension:"3D"
EditCreateR::
EditOperationTime:"00:00:00.5990337"
EditDrawTime:"00:00:01.3837081"
Creates("Rooftop Plan/Fence",14)
Creates("Rooftop Scene/Fence",14)
Task: Digitize Trees
ShapeType:"Point"
EditOperationTime:"00:00:00.2405487"
EditDrawTime:"00:00:02.8194469"
Creates("Rooftop Plan/Trees_screen",25,26,27,28,29,30)
Creates("Rooftop Scene/Trees_screen",25,26,27,28,29,30)
EditUndo::
EditOperations.Count:"2"
EditOperationTime Average:"00:00:00.2838930"
EditOperationTime Total:"00:00:00.5677861"
EditDrawTime Average:"00:00:01.4050822"
EditDrawTime Total:"00:00:02.8101644"
3D Plan View, Rooftop Scene, 00:00:05.8524316, 165.779690470519, 27.6422966144703, 54, 2021-06-01T11:59:47.3506168Z
PerfTools Script Execution Time = 00:00:32.1669386
SPATIAL ANALYSIS
06/01/2021 08:02 STDOUT INFO Test: SpatialAnalysis
06/01/2021 08:02 STDOUT INFO 2.8.0.29751
06/01/2021 08:03 STDOUT INFO =====Slope successful=====
06/01/2021 08:03 STDOUT INFO Slope: 38.374
06/01/2021 08:14 STDOUT INFO =====SlopeTest dataset created=====
06/01/2021 08:14 STDOUT INFO SlopeTest dataset: 669.385
06/01/2021 08:24 STDOUT INFO =====Aspect successful=====
06/01/2021 08:24 STDOUT INFO Aspect: 592.479
06/01/2021 08:24 STDOUT INFO =====AspectTest dataset created=====
06/01/2021 08:24 STDOUT INFO AspectTest dataset: 0.493
06/01/2021 08:25 STDOUT INFO =====Viewshed successful=====
06/01/2021 08:25 STDOUT INFO Viewshed: 56.064
06/01/2021 08:25 STDOUT INFO =====ViewshedTest dataset created=====
06/01/2021 08:25 STDOUT INFO ViewshedTest dataset: 0.5
06/01/2021 08:25 STDOUT INFO CUDA/GPU processing DISABLED
2D RENDERING
Zoom To Bookmarks Script
Home, Layers, 00:00:00.0010852, 151.080799388886, 31.6618938446045, 1, 2021-06-01T11:43:12.0524599Z
Home, Layers, 00:00:07.3462597, 153.379304116708, 27.3261219724532, 62, 2021-06-01T11:43:28.3018019Z
Springwater Drive, Layers, 00:00:06.5677465, 159.869227756365, 25.8038719008203, 61, 2021-06-01T11:43:39.9504417Z
Woodstock/52nd, Layers, 00:00:06.8780010, 150.616159735593, 26.6682266576681, 64, 2021-06-01T11:43:51.8989298Z
Reed College Campus, Layers, 00:00:06.6118607, 110.321221997756, 26.2433075470025, 61, 2021-06-01T11:44:03.5855518Z
Gladstone Street, Layers, 00:00:06.1533160, 167.665385967001, 24.5933879151156, 57, 2021-06-01T11:44:14.8158541Z
Powel/26th, Layers, 00:00:06.8479030, 106.113119996211, 26.1235184443649, 64, 2021-06-01T11:44:26.7394748Z
I405/I5, Layers, 00:00:06.5500846, 111.148903051369, 25.4940740168095, 61, 2021-06-01T11:44:38.3630885Z
Burnside/I405, Layers, 00:00:07.6566880, 139.040721124327, 27.7432928085327, 71, 2021-06-01T11:44:51.0984019Z
PGE Park, Layers, 00:00:06.9660749, 118.98439404318, 25.7470573778264, 64, 2021-06-01T11:45:03.1374028Z
Jefferson Street, Layers, 00:00:06.4353537, 137.013936145848, 26.2562834906081, 60, 2021-06-01T11:45:14.6376592Z
DrawTime Sum: 00:01:08.0143733, Count: 11, Average: 00:00:06.1831248
AverageFPS Sum: 83348.4098860699, Count: 616, Average: 135.305860204659
MinimumFPS Sum: 16161.8213326633, Count: 616, Average: 26.2367229426352
FPSSampleRate = 100 ms
PerfTools Script Execution Time = 00:02:08.4407608
==================3D RENDERING------------------------
Home, Globe layers, 00:00:05.6858308, 28.9506554950315, 4.62908043196568, 52, 2021-06-01T11:50:52.6230286Z
Fountain, Globe layers, 00:00:26.9353830, 26.1736212523855, 7.88106521471374, 248, 2021-06-01T11:51:24.8112083Z
Park Bench, Globe layers, 00:01:14.9247210, 35.3630635012331, 16.173318728696, 686, 2021-06-01T11:52:45.0723788Z
City Streets, Globe layers, 00:01:00.7292565, 52.9667794150754, 19.9491436296015, 556, 2021-06-01T11:53:50.9410311Z
Hotel Side View, Globe layers, 00:00:46.3354435, 49.7915060474903, 14.9774945382541, 422, 2021-06-01T11:54:42.5611158Z
Tower Top, Globe layers, 00:00:26.5354691, 54.6623844061532, 20.8003929701362, 243, 2021-06-01T11:55:14.2933762Z
Zoom Out From Tower, Globe layers, 00:00:20.4092124, 52.9463457119696, 18.7810597868367, 187, 2021-06-01T11:55:39.7831833Z
Pan Left To Cathedral, Globe layers, 00:00:20.2073422, 52.0174147603845, 14.2306178931309, 184, 2021-06-01T11:56:05.8575009Z
Two Cathedral Tops, Globe layers, 00:00:18.7536073, 51.5641485829455, 16.2826919292295, 172, 2021-06-01T11:56:29.7681601Z
Cathedral Overview, Globe layers, 00:00:38.0621602, 49.6531472808039, 17.9066013911563, 349, 2021-06-01T11:57:13.0413117Z
River View, Globe layers, 00:00:17.5259442, 46.3785886318109, 13.359831850351, 161, 2021-06-01T11:57:35.8499766Z
DrawTime Sum: 00:05:56.1043702, Count: 11, Average: 00:00:32.3731245
AverageFPS Sum: 148708.51636684, Count: 3249, Average: 45.7705498205109
MinimumFPS Sum: 52956.26892066, Count: 3249, Average: 16.2992517453555
PerfTools Script Execution Time = 00:06:56.1005055
You still haven't posted any evidence this is "illegal". I registered for the program with a personal gmail address, the Insider Preview Agreement is the legally binding document under which the terms are governed. It's not just meant for OEMs. Register, accept the agreement that limits their liability, welcome to program! It's right in the first link you sent. And ArcGIS Pro is running like a champ in this environment.
Don't call MS or ESRI for support, obviously. And if MS hasn't released a version you can purchase within 180 days of installation, tough. But under no possible interpretation is this "illegal" and it's absurd to suggest it.
If you find a legal document that contradicts this, I'd love to see it. No blog posts, how-tos or other content inadmissible in court or arbitration, though.
Nope! Just because you can does not make it legal or ethical. Microsoft does not intend for Insider Previews to be run on ARM hardware/os combinations other than what they support (think Surface Pro X). The ARM 64 Windows os is available for OEM working on Microsoft approved architecture. That aint Apple M1 ARM.
https://docs.microsoft.com/en-us/windows-insider/developers/get-started
https://docs.microsoft.com/en-us/windows-insider/troubleshooting
Do this at your own peril--or your employer who's purchased an ArcGIS Pro seat for you.
Sorry that you are stuck with an unsupported M1 Apple, but that is the current state--legally.
Here's the Insider Preview Agreement. Which provision exactly is being violated here by testing ESRI software? I see none at all and would argue this kind of exercise is exactly why the preview exists. The Agreement simply limits Microsoft's exposure to liability.
https://insider.windows.com/en-us/program-agreement
@SeanAdlai if you have the time, it would be great if you could run the standardized tests from the ArcGIS Pro Performance Analysis Tool (PAT) on your M1 setup. (If you have not used PAT yet, please see the recent blog post for information on how to obtain and install it: Announcing the ArcGIS Pro Performance Assessment Tool (PAT).)
Hello Marcel.Here are the tests I performed
Hope this helps
It's true. I think, for now is just to see how work ArcGIS Pro on M1. Until Microsoft release windows for ARM which I'm doubtful. Microsoft will port the key product to Mac M1 but, for the windows itself it's an other game, unless PC makers start moving to ARM and Microsoft see business there.
Esri users will have to stick with PC (like me using my Mac with Remote Desktop to control that dedicated PC) or move away from ESRI product since for them, Mac are not in their business plan. At least what they tell us.
Hey VStuartFoote.really good questions1. I just signed up for the Insider beta and its a free download. I'm not using for production, so i'm not aware of any licensing violations. please let me know if I am. I want to know if ARM will work.2. I am a VMWare Fan. Will check and see. Thanks.
Two issues; one, Microsoft does not license its ARM 64 Windows you are violating your Insiders Preview use conditions; two, Windows ARM driver support for perifireals (digitizers, scanners, printers) is not there. Parralels bit, but VMWare is taking a pass for its Fusion product [1] until Microsoft's Windows 10 ARM licensing is clarified. Meanwhile this is not legal. Supposedly Microsoft is working on its own ARM Risc implementation--why would they license their ARM based Windows for use on M1 chips? They might, but why should they aid their competition?
[1] https://blogs.vmware.com/teamfusion/2021/04/fusion-on-apple-silicon-progress-update.html
Do you work with a Pc to see how this emulation stand? If so what Pc configuration you have. On M1 is slower, faster?
Hi Marcel.YesPro - 2.8Desktop - 10.8.1 No Issues so far.
Hi, Pro 2.8? Have you make some tests? Any issues?
