Refer to https://developers.arcgis.com/javascript/latest/sample-code/widgets-featuretable-map/, I loaded ESRI's FeatureTable widge into my App. What is the way to check on/off all of the rows dynamically thruough JavaScript code? Thanks if you can provide your hint.
You can select the rows using the object ids of the source layer.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-FeatureTable.html#selectRows
// select all rows const oids = await featureTable.layer.queryObjectIds(); featureTable.selectRows(oids);
Rene: Thanks for your response. What's the code to add/remove All of the row? Could you help?
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle kostenlos ein Konto.
