To Collector / FieldMaps experts,
What's the recommended way to capture the below types of geometries in Collector / FieldMaps?
1. donut polygons
2. multipart polygons
Thanks.
I don't see these functionalities available out-of-the-box in ArcGIS Collector. Some addition to the existing editing tools by Esri will help.
There is also a long pending idea Cut polygons/polylines in Collector for ArcGIS
As of now, the tasks have to be carried out as a part of post processing in ArcGIS Desktop/Pro.
Thanks for your response. To answer your question - donut and multipart polygons are common types of geometry in the real world for data capture.
Imagine you are collecting
For sure above can be handled with a field/office workflow with proper data model design. My goal is to find the easiest way for field user, even it requires post-process in the backend.
So far my understanding is for donut polygons, we will have an exclusion/island type in the data model, and we can process them in the backend by FME server.
For multipart features, input full attributes for the first feature and only the link_id for subsequent features. Dissolving/aggregation process will be handled by FME server in the backend.
As you can see, the above workaround does get the job done but requires some extra setup. I wonder if ESRI has a more elegant solution to capture those types of geometries, e.g. some functionalities or out-of-box workflow that I have missed.
I would recommend using ArcGIS Desktop for these tasks.
Why do you want to do it using Field Apps? Any particular business need?
