Hi everone,
I want to delete Subnetwork name. How can i make this.
I couldn't find a tool like this, Modify Subnetwork controllers tool is update features role but the old subnetwork name keep coming from the drop-down list.
anybody have any idea?
Hello, there is a process outlined here: https://pro.arcgis.com/en/pro-app/latest/help/data/utility-network/delete-a-subnetwork.htm
You want to use the modify subnetwork controller tool in the UN ribbon to manually delete the controllers you want to remove. After you remove them all, validate network topology and run the update subnetwork tool again. Then run the export subnetwork tool with the set export acknowledged to true. This will delete the subnetwork. Also, be sure to delete all controllers in the tier you want to remove. If you only delete a few within the network, the export will fail.
did you see the links at the bottom of this page?
Subnetwork controllers—ArcGIS Pro | Documentation
The help referenced above should help you get these removed and fully deleted from the subnetworks table. When you just remove the subnetwork controller using the Modify Subnetwork Controller pane, the subnetwork name is still listed in the system.
Are you still seeing the subnetwork name show up in the dropdown after all controllers that used that subnetwork name are removed and export subnetwork with ack is executed?
Thank you so much, its worked 👍
