Is there a way to set an initial default data frame extent e.g. centred on a particular place, WITHOUT preventing users from subsequently choosing to zoom out further, as is the case with the Data Frame Fixed Extent?
What's the scenario? If it's a blank MXD, the DF will move to the extent of initially added data.
Also Setting a custom full extent for your data frame—Help | ArcGIS for Desktop
Yes its a blank MXD.
The issue we have is that the initial data added is often our basemapping layer file which covers a much greater area than many users require. Of course we could just create 2 basemap layer files for users to choose between, but i wonder if there is more elegant solution?
Maybe a map template might be of use?
Link: Using map templates
While a map template is useful, in essence i was hoping that there was a way to save a spatial bookmark within a layer so that it opened at a specified extent.
Gotcha. Essentially, setting up a predefined area of interest / location of interest at the layer level, not the data frame level. Unfortunately, I don't think that is currently possible. The other option may be to request that they add the AOI data first, then the basemap? Make it part of the process?
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
