Hello,
I am trying to set up "CommunicationsDataManagementForArcGISEnterpriseV1" but get attached error during application of asset package.
Is this problem known and is there a solution/fix to it?
Thanks and best regards,Jürgen
Hi Paul,
With the help from Esri support (see case #02696389) we figured out that the problem was caused by a corrupted installation of the "pandas 1.1.3" package. Today, in another attempt to upgrade the untools, ArcGIS Pro installed "pandas 1.1.5" sucessfully and after that also "untools 2.6.2". Right now, I am applying the asset package of the Communication Data Management and it seems to be running successfully as well.
Best regards,Jürgen
Hi Jurgen
Was this asset package modified in any way after being downloaded?
Could you post the message section of the GP tool? This will provide us the version of ArcGIS Pro and the version of the untools.
Hi John
No, I didn't modify the asset package at all. Even the entire environment was set up completely anew with PostgreSQL 11 as enterprise database.
Regards,Jürgen
Hi Michael,
This is what the messages section reports:
ArcGIS Pro 2.6.3.24783
untools 2.6.0
Executing from ArcGIS Pro, 0 map(s), activeMap = False
Parallel processing enabled: 3
Asset Package schema version: 2.6
The asset package has the following errors (4/4): Item Field OID Value Message Level 0 B_Subnetwork_ConditionBarriers None None Switch: B_Subnetwork_Devices|B_Subnetwork_Lines A required subnetwork configuration is missing error 1 B_Subnetwork_ConditionBarriers None None Coax: B_Subnetwork_Devices|B_Subnetwork_Lines A required subnetwork configuration is missing error 2 B_Subnetwork_ConditionBarriers None None Copper: B_Subnetwork_Devices|B_Subnetwork_Lines A required subnetwork configuration is missing error 3 B_Subnetwork_ConditionBarriers None None Fiber: B_Subnetwork_Devices|B_Subnetwork_Lines A required subnetwork configuration is missing error
Failed to execute (AssetPackageToUtilityNetwork).
Did you have the time and opportunity to look into this?
Meanwhile, I made another test with a new download of the Communication Data Management model, the result was the same.
Thank you very much, best regards,Jürgen
I believe you need to update your version of untools
Hi Paul
I have untools 2.6.0 installed. I think there is no newer version of the untools.
Regards, Jürgen
https://solutions.arcgis.com/utilities/help/utility-network-automation/get-started/release-notes-2-6-0.htm
You should see an update in the packages list. Might need to refresh
Hi Matt (hope that's correct)
Thanks for sharing your observations. Since it is not only me that is facing this problem I assume that the problem is related to either the asset package or to the tools that are delivered by Esri. Instead of manipulating the asset package on my own (as you suggest) I would expect Esri to investigate the root cause and come up with an official solution or fix.
Anyone from the Esri solutions team: Please let me know what to expect and how to continue. Thank you.
So it is untools 2.6.2 we are looking for. Any idea how I can install it? As mentioned below, my ArcGIS Pro doesn't offer it for installation.
Can you try the steps from https://solutions.arcgis.com/utilities/help/utility-network-automation/get-started/frequently-asked-questions.htm#anchor2 ? I'm not sure why the refresh isn't showing it to you.
This log-file documents my unsuccessful attempt to upgrade the untools via Python Prompt. Does that give any clue?
Regards,Jürgen
(arcgispro-py3-clone) C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone>conda install -c esri untools --insecure --no-pin -vFetching package metadata .............Solving package specifications: .
Package plan for installation in environment C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone:
The following packages will be UPDATED:
pandas: 1.0.5-py36h47e9c7a_0 --> 1.1.3-py36ha925a31_0untools: 2.6.0-py36_1 esri --> 2.6.2-py36_0 esri
Proceed ([y]/n)? y
===> UNLINKING PACKAGE: defaults::pandas-1.0.5-py36h47e9c7a_0 <===prefix=C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone
===> UNLINKING PACKAGE: esri::untools-2.6.0-py36_1 <===prefix=C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone
===> LINKING PACKAGE: defaults::pandas-1.1.3-py36ha925a31_0 <===prefix=C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clonesource=C:\Users\j.biendara\AppData\Local\ESRI\conda\pkgs\pandas-1.1.3-py36ha925a31_0
An error occurred while installing package 'defaults::pandas-1.1.3-py36ha925a31_0'.CondaError: Cannot link a source that does not exist. C:\Users\j.biendara\AppData\Local\ESRI\conda\pkgs\pandas-1.1.3-py36ha925a31_0\Lib\site-packages\pandas-1.1.3.dist-info\INSTALLERAttempting to roll back.
===> REVERSING PACKAGE LINK: defaults::pandas-1.1.3-py36ha925a31_0 <===prefix=C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone
===> REVERSING PACKAGE UNLINK: esri::untools-2.6.0-py36_1 <===prefix=C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone
===> REVERSING PACKAGE UNLINK: defaults::pandas-1.0.5-py36h47e9c7a_0 <===prefix=C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone
An unexpected error has occurred.Please consider posting the following information to theconda GitHub issue tracker at:
https://github.com/conda/conda/issues
Current conda install:
platform : win-64conda version : 4.3.27conda is private : Falseconda-env version : 4.3.27conda-build version : 3.18.9python version : 3.6.8.final.0requests version : 2.22.0root environment : C:\Program Files\ArcGIS\Pro\bin\Python (writable)default environment : C:\Users\j.biendara\AppData\Local\ESRI\conda\envs\arcgispro-py3-cloneenvs directories : C:\Program Files\ArcGIS\Pro\bin\Python\envsC:\Users\j.biendara\AppData\Local\ESRI\conda\envsC:\Users\j.biendara\.conda\envspackage cache : C:\Users\j.biendara\AppData\Local\ESRI\conda\pkgsC:\Program Files\ArcGIS\Pro\bin\Python\pkgschannel URLs : https://conda.anaconda.org/esri/win-64https://conda.anaconda.org/esri/noarchhttps://repo.anaconda.com/pkgs/main/win-64https://repo.anaconda.com/pkgs/main/noarchhttps://repo.anaconda.com/pkgs/free/win-64https://repo.anaconda.com/pkgs/free/noarchhttps://repo.anaconda.com/pkgs/r/win-64https://repo.anaconda.com/pkgs/r/noarchhttps://repo.anaconda.com/pkgs/msys2/win-64https://repo.anaconda.com/pkgs/msys2/noarchconfig file : C:\Program Files\ArcGIS\Pro\bin\Python\.condarcnetrc file : Noneoffline mode : Falseuser-agent : conda/4.3.27 requests/2.22.0 CPython/3.6.8 Windows/10 Windows/10.0.17763administrator : True
`$ C:\Program Files\ArcGIS\Pro\bin\Python\Scripts\conda install -c esri untools --insecure --no-pin -v`
Traceback (most recent call last):File "conda\core\link.py", line 326, in _execute_actionsFile "conda\core\path_actions.py", line 230, in executeFile "conda\gateways\disk\create.py", line 246, in create_linkconda.CondaError: Cannot link a source that does not exist. C:\Users\j.biendara\AppData\Local\ESRI\conda\pkgs\pandas-1.1.3-py36ha925a31_0\Lib\site-packages\pandas-1.1.3.dist-info\INSTALLER
During handling of the above exception, another exception occurred:
Traceback (most recent call last):File "conda\core\link.py", line 281, in executeFile "conda\core\link.py", line 344, in _execute_actionsconda.CondaMultiError: Cannot link a source that does not exist. C:\Users\j.biendara\AppData\Local\ESRI\conda\pkgs\pandas-1.1.3-py36ha925a31_0\Lib\site-packages\pandas-1.1.3.dist-info\INSTALLER
Traceback (most recent call last):File "conda\exceptions.py", line 641, in conda_exception_handlerFile "conda\cli\main.py", line 144, in _mainFile "conda\cli\main_install.py", line 80, in executeFile "conda\cli\install.py", line 329, in installFile "conda\plan.py", line 830, in execute_actionsFile "conda\instructions.py", line 247, in execute_instructionsFile "conda\instructions.py", line 108, in UNLINKLINKTRANSACTION_CMDFile "conda\core\link.py", line 297, in executeconda.CondaMultiError: Cannot link a source that does not exist. C:\Users\j.biendara\AppData\Local\ESRI\conda\pkgs\pandas-1.1.3-py36ha925a31_0\Lib\site-packages\pandas-1.1.3.dist-info\INSTALLER
