I have a feature Layer hosted with a couple off fields. I have create a view from it wich I have published in my Web Mapping Application. Users are very satisfied with it, besides 1 little issue. They would have in some fields a default value. But how can I change the default value of fields in existing applications which are published and already filled? It concerns datasets which can be edit or where the user can add some objects.
Thank You for the reaction,
Marlies
Als het goed is kan dat door:
- Feature class to feature class in pro
- Dataset van AGOL leeggooien
- Nu kun je default waarde aanpassen
- Data weer appenden.
Beetje onlogisch, maar het werkt volgens mij wel.
