Error: not a valid multipart coverage response at WCSLayer.js:189 at c (3.33:104) at e (3.33:104) at b.Deferred.resolve.callback (3.33:105) at c (3.33:105) at e (3.33:104) at b.Deferred.resolve.callback (3.33:105) at c (3.33:105) at e (3.33:104) at b.Deferred.resolve.callback (3.33:105) "Error: not a valid multipart coverage response at https://js.arcgis.com/3.33/esri/layers/WCSLayer.js:189:109 at c (https://js.arcgis.com/3.33:104:350) at e (https://js.arcgis.com/3.33:104:139) at b.Deferred.resolve.callback (https://js.arcgis.com/3.33:105:479) at c (https://js.arcgis.com/3.33:105:63) at e (https://js.arcgis.com/3.33:104:139) at b.Deferred.resolve.callback (https://js.arcgis.com/3.33:105:479) at c (https://js.arcgis.com/3.33:105:63) at e (https://js.arcgis.com/3.33:104:139) at b.Deferred.resolve.callback (https://js.arcgis.com/3.33:105:479)"
I get this not a valid multipart coverage response. I have tired this with multiple WCS endpoints and get the exact same error specifically with WCS version 2.0.1.
Any idea what multipart coverage response it is expecting?
Has anyone had any success using the WCSLayer with WCS 2.0.1?
I included my test code to recreate the error.
Thanks.
Hi @PickBounty
Thanks for providing the test app for troubleshooting.
The GetCoverage response from server doesn't have a multipart MIME type header/body, it's simply TIFF. This is not supported by the API because a multipart coverage is required per WCS 2.0.1 spec, you may want to check server configuration or seek help from the vendor.
Multipart coverage encoding is a major difference between 1.0.0 and newer 2.0.1 version, here's the spec requirement:
[OGC 09-110r4] requirement 36:
The contents of the response to a successful GetCoverage request shall be encoded as specif- ied in GMLCOV [OGC 09-146r2] conformance class multipart where ...
OGC 09-146r2 requirement 19:
A coverage encoded in a multipart message shall consist of a multipart MIME document as specified by IETF RFC 2387
[OGC 09-146r2] requirement 19:
Hi @WenxueJu
Thank you very much for your response. I followed up with your recommendation and further investigation has allowed me to resolve the previous error but led me to another issue.
I no longer get the error. To solve this, I was able to pass through the mediatype parameter as part of the URL (?Mediatype=multipart/related). This returns a multipart response, however although there are no errors to report from the API the image is not rendered on the map.
I am actually not sure why the image does not render as there are no error flags being produced. I am wondering if this may be due to the API not being able to parse the XML properly?
I included an updated html for review.
Any thoughts?
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
