Hello,
I received the following request from my DBA:
"As you know, the installation of the software, requires to place some libraries at the server level. These libraries are then accessed via a plsql LIBRARY object.
Could you ask if they plan to “de-support/remove” this approach ? An alternative would be to provide the same functionality but using Java instead. The LIBRARY would then use java code stored in the DB itself, avoiding the need of this EXTPROC thingy that we need to setup now."
Any opinion ?
Thanks !
Nicolas
