How can I replicate my operations dashboard and have it linked to new data files without having to re-configure all the dependencies?
After copying the Dashboard, use the "I want to..." dropdown and select "View an Item's JSON".
In the Data portion, you can edit the itemId property to point to the new data.
I would give the AGO Assistant tool a try: ArcGIS Online Assistant
You can point to your Dashboard item and then create a copy of it.
You could also do this with all of the dependencies and then edit as you see fit.
Thanks for the quick response. However, if I just copy the dashboard the pointers will still point to the original data files. I need a way to edit the dashboard so they point to new files.
Hi David,
Please vote for the enhancement on the ArcGIS Ideas site, Operation dashboard - Add the ability to save as a template
Hope this helps,
This looks like what I need, but where do I find the “I want to …” dropdown?
Hello Brian and all,
I followed the same steps to clone an ops dashboard but in the ArcGIS Online Assistant tool the targeted ops dashboard isn't getting highlighted I mean it can't be dragged and dropped in order to copy it - please see the photo below
How can I clone such a dashboard then? Thanks.
This is a limitation of the tool - but there is a workaround.
If you are just looking to copy the dashboard in the same organization (I didn't test between organizations, but it should work as long as you duplicate the map and then update the JSON to point to that map).
So - what I did is to just create a new dashboard (can be blank) and then in the AGO Assistant tool, go to 'View an Item's JSON' - now, copy the JSON in the Data section - and then paste it into your 'new' dashboard. This will copy all of the configurations, etc. over.
