I would love it to be easier to set the order of fields appearing in a pie chart.
I have charts displaying around 24 fields because that is the resolution of data my client wants. To make the pies more intelligible to the reader, I ensure similar categories are drawn alongside one another and given different tones of the same colour. However, I find the field order control is frustrating to use. It would be great if I could:
- Rescale the window to see more fields at once.
- Select multiple fields at once to move up or down the sequence.
- Use drag and drop to reorder fields.
I would also like it if changing the order of the fields did not reset defaults. Changing the order of fields can undo changes I have made to the symbology for each field and refinements I have made to the field names appearing in the map's table of contents.
