Allow any widget or element to be draggable/resizable (add Draggable and Resizable properties to 4x API - View UI). This would allow popups to move or resize. Or a LayerList. Or Search widget. Or any widget or DOM element that would make sense to register with View UI as moveable. Also add an autofit property true/false and with padding parameter; to allow popups to autosize in height or widgth and with given extra padding or margin. Seems like the perfect place to add this vital functionality to the API.
UI | ArcGIS API for JavaScript 4.16
I have created moveable popups for JS API 4.x. Example: https://codepen.io/kevinsagis/full/bGpdQQq
It hides the callout on move with CSS; and is moveable via titlebar. Last thing to do still is implement a leader line that follows it like a callout. Using jQuery which is still awesome in 2020!
This example above with jQuery will work for any widget you could put in a div like I have in this example. It would be great to see moving integrated natively in this fashion.
Melde dich an, um Beiträge zu veröffentlichen, Inhalten zu folgen und mehr. Neu hier? Registriere dich kostenlos.
