I have a map that covers a large area. One layer I have in my map is local roads and I have used the label feature to label all of the local roads on my map. Since the map covers a large area, there are several local roads in the view. Labeling all of the roads clutters the map.
I would like to have the option to label only 50% of the roads. This could be something such a slide bar similar to changing the transperancy. If you want 10% of the roads to be labeled or 73% of the roads to be labeled you could slide the bar to your desired setting.
