I recently discovered Display Filters in ArcGIS Pro, with which you can apply filters to different map scales for a layer. When you use the [+ Add Display Filter] button, to add a new display filter to your list of filters, there is no mechanism to move it up or down in the list. It seems to add it to the smallest end of the map scales, and you can only Add/Delete to get it in the scale range you want.
