Because temporary rasters that must be written to disk in arcpy map algebra are written in Esri grid format to a folder, it is best practice for heavy map algebra to set the workspace and scratchWorkspace environments to the same folder.
If the scratch and current are written to the same folder, the operation:
raster = CreateConstantRaster(1)
raster.save("mygrid")will rename the temp grid (named something like createconsta_1) to "mygrid". If the workspace is not a folder or scratchWorkspace is somewhere else, the raster will have to be copied (and maybe converted, say from grid to .gdb), not renamed. This can take a while for large rasters, and since heavy map algebra can be very processing intensive, why not cut a corner!
Here's an example run from the ArcMap Python window:
>>> env.workspace = r"D:\Users\cprice\work\Default.gdb"
>>> RasterWorkspace(1)
workspace:
scratchWorkspace:
\Users\cprice\work\scratch
Set to:
workspace:
scratchWorkspace:
>>> env.workspace = r"D:\Users\cprice\work"
>>> RasterWorkspace(1)
workspace:
\Users\cprice\work
scratchWorkspace:
Set to:
workspace:
\Users\cprice\work
scratchWorkspace:
\Users\cprice\work
def RasterWorkspace(report=False):
"""Set a raster workspace (folder) based the current workspace.
If the current workspace is a valid folder,
workspace, and scratchWorkpace will be set to that location.
Otherwise, the current workspace is set to env.scratchFolder.
This is done because arcpy map algebra work most efficiently if the
current and scratch workspace are set to the same system folder
(not a geodatabase)
import arcpy
from arcpy import env
if report:
print(" workspace: {}\n scratchWorkspace: {}".format(
env.workspace, env.scratchWorkspace))
try:
if env.workspace:
if not arcpy.Exists(env.workspace):
raise Exception("Current workspace '{}' not found".format(env.workspace))
if arcpy.Describe(env.workspace).DataType == "Folder":
env.scratchWorkspace = env.workspace
else:
env.workspace = env.scratchFolder
env.scratchWorkspace = env.scratchFolder
else:
raise Exception("Current workspace not set")
except Exception as msg:
print("Warning: " + msg)
print("Warning: " + "Using {}".format(env.scratchFolder))
if report:
print("\nSet to:\n"
return
