Arcpy
You need to create a Point object
<SPAN class="keyword token">import</SPAN> arcpy
pnt <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Point<SPAN class="punctuation token">(</SPAN><SPAN class="number token">300000</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">5025000</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN><SPAN class="punctuation token">(</SPAN>pnt<SPAN class="punctuation token">)</SPAN>
<SPAN class="number token">300000</SPAN> <SPAN class="number token">5025000</SPAN> NaN NaN<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Simple... But what does that... import arcpy ...line do?
Let's see
(1) ---- Direct import
| dir(arcpy) ...
| <module 'arcpy' from 'C:\\ArcGISPro\\Resources\\ArcPy\\arcpy\\__init__.py'>
(001) ASCII3DToFeatureClass_3d ASCIIToRaster_conversion AcceptConnections
(004) AddAngleDirectedLayout_un . . . SNIP . . .
(1174) stats stpm sys
(1177) td time toolbox
(1180) topographic un utils
(1183) warnings winreg wmx
That's correct... about 1200 names added to python's namespace.
(2) ---- Alternatives?
arcgisscripting
<SPAN class="comment token"># ---- arcgisscripting is located in the folder</SPAN>
<SPAN class="comment token"># C:\{your_install_path}\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgisscripting</SPAN>
<SPAN class="comment token"># In there there is an arcgisscripting.pyd file</SPAN>
<SPAN class="keyword token">import</SPAN> arcgisscripting <SPAN class="keyword token">as</SPAN> ags
dir<SPAN class="punctuation token">(</SPAN>ags<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'ClearCredentials'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ExecuteAbort'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ExecuteError'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ExecuteWarning'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Extent'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'ImportCredentials'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'NumPyArrayToRaster'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Raster'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'RasterToNumPyArray'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'SignInToPortal'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__builtins__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__cached__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__doc__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__file__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__loader__'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'__name__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__package__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__path__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__spec__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_addTimeInterval'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_analyzeForSD'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'_arcgisscripting'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_attachLocator'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_chart'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_convertWebMapToMapDocument'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'_createGISServerConnectionFile'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_createGeocodeSDDraft'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_createMapSDDraft'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'_createimageservicesddraft'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_getImageEXIFProperties'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_getRasterKeyMetadata'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_getUTMFromLocation'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_hasLocalFunctionRasterImplementation'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_hgp'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_ia'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'_listDateTimeStringFormats'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_listStyleItems'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_listTimeZones'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_mapping'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'_reserved'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_setRasterKeyMetadata'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_sharing'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_ss'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_wrapLocalFunctionRaster'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'_wrapToolRaster'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'create'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'da'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'getmytoolboxespath'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'getsystemtoolboxespath'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'getsystemtoolboxespaths'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'na'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'un'</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="comment token"># ---- how about the *data access* stuff??</SPAN>
dir<SPAN class="punctuation token">(</SPAN>ags<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">[</SPAN><SPAN class="string token">'ContingentFieldValue'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ContingentValue'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'DatabaseSequence'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Describe'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Domain'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'Editor'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ExtendTable'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'FeatureClassToNumPyArray'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'InsertCursor'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'ListContingentValues'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ListDatabaseSequences'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ListDomains'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'ListFieldConflictFilters'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ListReplicas'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ListSubtypes'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'ListVersions'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'NumPyArrayToFeatureClass'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'NumPyArrayToTable'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Replica'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'SearchCursor'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'TableToNumPyArray'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'UpdateCursor'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Version'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'Walk'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__doc__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__loader__'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'__name__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__package__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'__spec__'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_internal_eq'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_internal_sd'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'_internal_vb'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>arcobjects
<SPAN class="keyword token">from</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>arcobjects <SPAN class="keyword token">import</SPAN> Point<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
dirr(Point)
| dir(Point) ...
| <class 'arcpy.arcobjects.arcobjects.Point'>
(001) ID M X Y
(005) Z __class__ __cmp__ __delattr__
(009) __dict__ __dir__ __doc__ __eq__
(013) __format__ __ge__ __getattribute__ __gt__
(017) __hash__ __init__ __init_subclass__ __le__
(021) __lt__ __module__ __ne__ __new__
(025) __reduce__ __reduce_ex__ __repr__ __setattr__
(029) __sizeof__ __str__ __subclasshook__ __weakref__
(033) _arc_object _go clone contains
(037) crosses disjoint equals
(041) overlaps touches within
(3) ---- The data access module
Get less fluff when working with tables, and featureclasses. Compare to the arcgisscripting import... any differences?
dirr(arcpy.da, cols=3)
| dir(arcpy.da) ...
| <module 'arcpy.da' from 'C:\\ArcGISPro\\Resources\\ArcPy\\arcpy\\da.py'>
(001) Describe Domain Editor
(004) ExtendTable FeatureClassToNumPyArray InsertCursor
(007) ListDomains ListFieldConflictFilters ListReplicas
(010) ListSubtypes ListVersions NumPyArrayToFeatureClass
(013) NumPyArrayToTable Replica SearchCursor
(016) TableToNumPyArray UpdateCursor Version
(019) Walk __all__ __builtins__
(022) __cached__ __doc__ __file__
(025) __loader__ __name__ __package__
(028) __spec__ _internal_eq
(031) _internal_sd _internal_vb
(4) ---- Arcobjects geometry
dirr(geo)
| dir(arcpy.arcobjects.geometries) ...
| <module 'arcpy.arcobjects.geometries' from 'C:\\ArcGISPro\\Resources\\ArcPy\\arcpy\\arcobjects\\geometries.py'>
(001) Annotation AsShape Dimension Geometry
(005) Multipatch Multipoint PointGeometry Polygon
(009) Polyline __all__ __builtins__ __cached__
(013) __doc__ __file__ __loader__ __name__
(017) __package__ __spec__ basestring
(021) gp operator xrange
but it import gp as well.
(5) ---- Arcobjects
import arcpy.arcobjects as arco
dirr(arco, cols=3)
| dir(arcpy.arcobjects.arcobjects) ...
| <module 'arcpy.arcobjects.arcobjects' from 'C:\\ArcGISPro\\Resources\\ArcPy\\arcpy\\arcobjects\\arcobjects.py'>
(001) ArcSDESQLExecute Array Cursor
(004) Extent FeatureSet Field
(007) FieldInfo FieldMap FieldMappings
(010) Filter GeoProcessor Geometry
(013) Index NetCDFFileProperties Parameter
(016) Point RandomNumberGenerator RecordSet
(019) Result Row Schema
(022) SpatialReference Value ValueTable
(025) _BaseArcObject __builtins__ __cached__
(028) __doc__ __file__ __loader__
(031) __name__ __package__ __spec__
(034) convertArcObjectToPythonObject mixins passthrough_attr
(6) ---- environments perhaps?
from arcpy.geoprocessing import env
dirr(env, cols=3)
| dir(<class 'arcpy.geoprocessing._base.GPEnvironments.<locals>.GPEnvironment'>) ...
| np version
(001) MDomain MResolution MTolerance
(004) S100FeatureCatalogueFile XYDomain XYResolution
(007) XYTolerance ZDomain ZResolution
(010) ZTolerance __class__ __delattr__
(013) __delitem__ __dict__ __dir__
(016) __doc__ __eq__ __format__
(019) __ge__ __getattribute__ __getitem__
(022) __gt__ __hash__ __init__
(025) __init_subclass__ __iter__ __le__
(028) __lt__ __module__ __ne__
(031) __new__ __reduce__ __reduce_ex__
(034) __repr__ __setattr__ __setitem__
(037) __sizeof__ __str__ __subclasshook__
(040) __weakref__ _environments _gp
(043) _refresh addOutputsToMap autoCancelling
(046) autoCommit baDataSource buildStatsAndRATForTempRaster
(049) cartographicCoordinateSystem cartographicPartitions cellSize
(052) coincidentPoints compression configKeyword
(055) extent geographicTransformations isCancelled
(058) items iteritems keys
(061) maintainAttachments maintainSpatialIndex mask
(064) nodata outputCoordinateSystem outputMFlag
(067) outputZFlag outputZValue overwriteOutput
(070) packageWorkspace parallelProcessingFactor preserveGlobalIds
(073) processingServer processingServerPassword processingServerUser
(076) pyramid qualifiedFieldNames randomGenerator
(079) rasterStatistics referenceScale resamplingMethod
(082) scratchFolder scratchGDB scratchWorkspace
(085) scriptWorkspace snapRaster terrainMemoryUsage
(088) tileSize tinSaveVersion transferDomains
(091) transferGDBAttributeProperties values workspace
(7) ---- Know your imports.
More to come
