I'm trying to strip out the ArcGIS Pro UI via DAML.
This bit works:
<backstage>
<deleteButton refID="esri_core_saveProjectButton" />
<deleteButton refID="esri_core_saveProjectAsButton" />
<deleteButton refID="esri_core_showOptionsSheetButton"/>
<deleteTab refID="esri_core_AddInsTab"/>
<deleteTab refID="esri_core_CondaTab"/>
<deleteTab refID="esri_core_LicensingTab"/>
</backstage>
</ArcGIS>
but if I use something like this
<updateModule refID="esri_mapping" caption="Mapping" description="Mapping">
<dockPanes>
<deleteDockPane refID="esri_mapping_symbologyDockPane"/>
<deleteDockPane refID="esri_mapping_labelClassDockPane"/>
<deleteDockPane refID="esri_mapping_popupsDockPane" />
<deleteDockPane refID="esri_mapping_locateDockPane"/>
<deleteDockPane refID="esri_mapping_geocodeTableDockPane"/>
<deleteDockPane refID="esri_mapping_animationDockPane"/>
<deleteDockPane refID="esri_mapping_animationEditorDockPane"/>
<deleteDockPane refID="esri_mapping_animationPreviewDockPane"/>
<deleteDockPane refID="esri_mapping_animationTimelineDockPane"/>
<deleteDockPane refID="esri_mapping_temporalViewerDockPane"/>
<deleteDockPane refID="esri_mapping_annotationDockPane"/>
<deleteDockPane refID="esri_mapping_annotationClassCreateDockPane"/>
<deleteDockPane refID="esri_mapping_interactiveAnalysisDockPane"/>
</dockPanes>
</updateModule>
It doesn't - these items are still visible / usable in the ArcGIS Pro UI. I can nuke it via var someElements = from seg in database.Root.Descendants(nsp + "module") select seg; and removing the elements but I'm sure this will cause null exceptions down the track. Why isn't the DAML being honoured? I'm missing something.
Fraser
