I need to create a geoform with subtypes and default values for some fields. I have a problem with fields with default values assigned. Any field with a default value will not be visible until the subtype is picked and then it shows up in the wrong order. If I remove the default value for this field or don’t use subtypes everything works fine. This seems to be a reproducible problem.
Here is an example: http://arcg.is/1Ys1wYJ
There is a field (titled “Field that moves”) that doesn’t show up until you select the subtype (first field) and then it shows up in the wrong order (this field is set up to be last in the list).
Any insight?
