So I have been tasked with parsing through a large amount of data. The data is in HDF5 file format and has about 30 raster layers within each HDF5. I need to be able to open up a specific layer from within these HDF files. For eaxmaple, I have been working with opening up the 20th layer. If i normally add the HDF (like any other data through the add data button), I get prompted to select a layer (which is when I select layer 20), but then I get prompted that there is "inconsistent spatial extent error". I tried
