I am having an issue where a user gets an insufficient permissions error when attempting to edit features that are components of a geometric network. The user has Select, Insert, Update, and Delete access to the dataset in which the network resides, but they are still unable to edit or delete features that participate in the network. Attached is a screenshot of the error, showing that they do not have permissions to the table that exists in the backend of the Esri Geometric Network. This issue did not begin happening until after I deleted the original Geometric Network in order to load data into one of the feature classes. I recreated the network, and then the error began. Can anyone shed any light on to how these networks work so that I might correct the issue?
We are using ArcGIS for Server 10.1 installed with SQL Server 2008 R2 for hosting our data, as well as ArcGIS Desktop 10.2.2 Advanced for editing.
Please let me know if this question is in the wrong area, and I will move it to the correct one.
Thank You!
Damon Myers
